James Racing Tires >
James Racing Tires
Like Tree60Likes
James Racing Tires
    Hide Wikipost
Old 04-22-2019, 12:23 PM   -   Wikipost
R/C Tech ForumsThread Wiki: James Racing Tires
Last edit by: Evoking1230
James Racing Tire Prep/Gluing Tips
1. Use non-chlorinated brake cleaner or Alcohol to clean bead of tire.
2. Dremel wheel bead. This gives it a good bonding surface. Clean after dremel with above cleaners mentioned above.
3. Use loctite professional glue.
4. Enjoy!
What James Racing Tires are compared to in other brands:
PL suppressor - Y-Zip
PL lockdown - Revenger
PL fugetive - Defenders
PL blockade - Y-Zip or Revenger
PL switchblade - Wasper
Dot Evo works on wet or dusty tracks and every track condition.
Wasper is like a Hole Shot/Buck Shot.
I-Blocks are amazing on dusty blue grooves.
X-Cross is like a Bow Tie.
The rubber wears like iron and the SS compound is close to a M3 PL and if sauced with PB Blaster, feels like a M4. The 5 rib inserts are like Dirt Techs so they don't break down fast like PL foams do.
"Compound Chart"
Originally Posted by Evoking1230
So is there a chart for which compound to go with in what weather/conditions?
I live in Texas and currently in the 70ís-80ís. Lately, occasional 50ís-60ís. And of course the 90ís in the summer and then some.
Thanks.
/Quote
There is no chart, but traction level is more important than temps. Use SS for low grip, Soft for high grip, and Medium for extreme/abrasive grip levels.
Print Wikipost
Old 04-29-2019, 05:31 AM
  #286
Originally Posted by VPProUSA View Post
Dot Evo. It works wet or dry. The Wasper and all other patterns work once it grooves up.
Dot Evo compares to Proline Hole Shots and is super versatile.
Great thank you so much. I really like the tires.
Will order a set of Waspers to have in hand.
sebtarta is offline
Old 05-15-2019, 12:06 AM
  #287
nickcza's Avatar
I found this chart on the James Racing Europe website, translated by Google:
James Racing Tire Chart
The chart is missing: Defender, Revenge, Square Cracker, Super Cross (in second chart)
For reference, a link to Facebook with this chart was posted by someone earlier in this thread:
Maybe someone with extensive experience with these tires could update the chart and sticky?
nickcza is offline
Old 05-15-2019, 10:04 PM
  #288
Trader Rating: 14 (100%+)
After some time not using the Y-Zip tire, I went back to it this past weekend. Supersoft Y-Zip on a hard-packed, cool, and slightly damp track was just outstanding.
robracing is offline
Old 05-20-2019, 03:39 PM
  #289
petersen114's Avatar
Do the James wheels still come pre-drilled??
petersen114 is offline
Old 05-20-2019, 03:46 PM
  #290
VPProUSA's Avatar
The rubber tires have a hole but not the wheels.
VPProUSA is offline
Old 05-20-2019, 04:16 PM
  #291
So the wheels have no vent holes, but the tires do have vent holes? Does this apply to the pre-glued option??
  #292
frewster's Avatar
Looking forward to ordering some Waspers soon. I haven't bought a new set of tires in years haha.
frewster is offline
Old 05-20-2019, 04:20 PM
  #293
VPProUSA's Avatar
Correct. That is for pre-glued only. Unglued tires do not have holes.
petersen114 likes this.
VPProUSA is offline
Old 05-20-2019, 04:35 PM
  #294
Thanks. Will order a set.
Old 05-20-2019, 04:37 PM
  #295
Crap!!!! Not in stock.
Old 05-20-2019, 04:39 PM
  #296
VPProUSA's Avatar
A shipment is coming late next week
VPProUSA is offline
Old 05-20-2019, 05:50 PM
  #297
frewster's Avatar
What compound/tire would be best for high grip clay?
frewster is offline
Old 05-20-2019, 05:53 PM
  #298
VPProUSA's Avatar
Soft Wasper usually.
frewster likes this.
VPProUSA is offline
