James Racing Tires >
James Racing Tires
Like Tree46Likes
James Racing Tires
Old 12-05-2014, 01:56 PM
  #16
Intech BR-6's Avatar
Originally Posted by Dizzyka View Post
does anyone have experience with the 1/10 clay compounds?
I have not tested the 1/10 tires yet. But they feel pretty good. They are a soft clay rubber. According to James, they are a mix of Natural and Synthetic rubber, so they are soft and have traction but still have long wear like a pure clay rubber. They are also very thick and have lots of webbing to prevent ballooning.
Intech BR-6 is offline
Old 12-05-2014, 02:03 PM
  #17
It's not just the rubber that makes them good, the ultra light 2-stage foam inserts and ultra light weight wheels make a set of tires an average of 32g lighter then other brands. Less rotating mass is the key to acceleration, cooler engine temps, longer fuel mileage, and better handling. They don't even need to be balanced because they are so light.
Old 12-05-2014, 02:10 PM
  #18
madweazl's Avatar
8 grams changes the need to balance tires?
madweazl is offline
Old 12-05-2014, 02:12 PM
  #19
That and the rims and tires and inserts are very true.
Old 12-05-2014, 02:26 PM
  #20
GSMike's Avatar
I knew I should have got the James wheels.
GSMike is offline
Old 12-10-2014, 06:22 PM
  #21
Trader Rating: 14 (100%+)
What is the advantage(s) of the two-stage insert?
robracing is offline
Old 12-10-2014, 07:12 PM
  #22
The stiff inside of the foam will help the tire keep its proper shape but the soft outside will provide better traction.
RedRockHobbies is offline
Old 12-10-2014, 09:33 PM
  #23
Correct. But also these foams are not made of the same material as normal closed cell inserts. They are a super light foam material. We ran a set of super soft tires until they went bald and then cut them open. The foam was a little softer but still intact and in the same shape as new, same condition as an AKA or VP-Pro insert is after 40+ minutes of running.
Old 12-10-2014, 09:45 PM
  #24
One thing I do recommend is taping off the holes in the rims. I punch 2 holes in the rubber. That keep dirt and water out of the foams.
Old 12-11-2014, 03:38 PM
  #25
madweazl's Avatar
Punching holes in the tires vice wheels keeps dirt and water off the foam?
madweazl is offline
Old 12-11-2014, 03:58 PM
  #26
Yes any dirt/dust/water that gets in the wheel will get pushed into the tire if there is holes in the rim from centrifugal force. While the holes in the tires allows any dirt and water to get spun out as the tire spins.
Years ago when Proline had holes in their wheels, I ran a set of crimefighters all day on a sandy track. At the end of the day when I took the wheels off, they each weighed about a pound because they were full of sand and the molded foams were hard as a rock.
Old 12-17-2014, 01:58 PM
  #27
Can't wait to get my hands on a couple of sets to try out
tgeary84 is offline
Old 12-17-2014, 02:00 PM
  #28
James Racing Super Soft Dot Evos takes TQ and First in 1/8th scale Sportsman Buggy, 1st in Sportsman E-buggy, 2nd in Pro Buggy, and 2nd in Pro E-Buggy in Florida last weekend!
Old 12-18-2014, 11:19 AM
  #29
joey91473's Avatar
Trader Rating: 18 (100%+)
I ran my first race last weekend with the James Tires Dot Evo's in supersoft compound. They were dialed. I ran practice, 3 quals and a 20 minute main with the same set. Hardly any wear and they handled great on my MBX7R buggy. give them a try, they are very good tires and the rubber feels great.
Attached Thumbnails James Racing Tires-img_20141214_162034_256.jpg   James Racing Tires-img_20141214_161904_415.jpg
joey91473 is offline
Old 12-19-2014, 10:30 AM
  #30
Trader Rating: 49 (93%+)
I ran a set of super softs last weekend in two different race's ran one heat and a 30min main at one track and 2 heats and another 30 min main at another track and they where not slicks yet but pretty Close id say i got my moneys worth out of the super softs i have a set of Soft Dot Evo's that i have over 2 hours of run time on no issues!
tcb22185 is offline
