James Racing Tires >
James Racing Tires
Like Tree58Likes
James Racing Tires
    Hide Wikipost
Old 04-22-2019, 12:23 PM   -   Wikipost
R/C Tech ForumsThread Wiki: James Racing Tires
Last edit by: Evoking1230
James Racing Tire Prep/Gluing Tips
1. Use non-chlorinated brake cleaner or Alcohol to clean bead of tire.
2. Dremel wheel bead. This gives it a good bonding surface. Clean after dremel with above cleaners mentioned above.
3. Use loctite professional glue.
4. Enjoy!
What James Racing Tires are compared to in other brands:
PL suppressor - Y-Zip
PL lockdown - Revenger
PL fugetive - Defenders
PL blockade - Y-Zip or Revenger
PL switchblade - Wasper
Dot Evo works on wet or dusty tracks and every track condition.
Wasper is like a Hole Shot/Buck Shot.
I-Blocks are amazing on dusty blue grooves.
X-Cross is like a Bow Tie.
The rubber wears like iron and the SS compound is close to a M3 PL and if sauced with PB Blaster, feels like a M4. The 5 rib inserts are like Dirt Techs so they don't break down fast like PL foams do.
"Compound Chart"
Originally Posted by Evoking1230
So is there a chart for which compound to go with in what weather/conditions?
I live in Texas and currently in the 70ís-80ís. Lately, occasional 50ís-60ís. And of course the 90ís in the summer and then some.
Thanks.
/Quote
There is no chart, but traction level is more important than temps. Use SS for low grip, Soft for high grip, and Medium for extreme/abrasive grip levels.
Print Wikipost
Old 04-14-2019, 05:02 PM
  #271
Ok is it just me or something whacky here!?!
I know how to glue wheels/tires. Never had them come off until now on the Pentangles I recently purchased.
I sanded the lip on the wheels, washed, prepped both rubber surfaces and plastic surfaces with alcohol but they are still coming undone. This is the 2nd time now. Maybe my glue? But I glued up some Jconcepts tires/wheels and they held 90+ laps today.
Evoking1230 is offline
Old 04-14-2019, 05:26 PM
  #272
Big Will's Avatar
When did you buy the glue? If it gets old it won't hold. It's a crap shoot really because there is no telling how long the stuff sat in storage/on shelf. They need to put "born on dates" on glue bottles.
Big Will is offline
Old 04-14-2019, 05:36 PM
  #273
VPProUSA's Avatar
I use non-chlorinated brake clean to clean bead of tire. Dremel wheel bead. Use loctite professional glue. Glued up about 12 sets of Pentangle and ran until bald with no issues in 2017-2018.
VPProUSA is offline
Old 04-14-2019, 06:57 PM
  #274
Ok Iíll give this a go.
Thanks.
  #275
agreed.
Old 04-14-2019, 10:32 PM
  #276
Is this the glue?
sebtarta is offline
Old 04-15-2019, 05:06 AM
  #277
hyperfuxx's Avatar
Trader Rating: 27 (97%+)
That's the glue I started using last season and haven't had a problem yet. I just clean the tire with simple green and that's it. No extra elbow work needed. Old glue can definitely be the culprit
hyperfuxx is offline
Old 04-15-2019, 12:09 PM
  #278
Originally Posted by sebtarta View Post
Is this the glue?
Well...just ordered like 3 of these so they better be good!
sebtarta and billdelong like this.
Old 04-16-2019, 09:57 AM
  #279
Big Will's Avatar
How thick is the Loctite glue? I used Gorilla glue with very good results but I would say it is thicker than most medium RC tire glue.
Big Will is offline
Old 04-16-2019, 10:16 AM
  #280
VPProUSA's Avatar
Same as AKA glue. It is a medium-thin.
Big Will likes this.
VPProUSA is offline
Old 04-16-2019, 10:25 AM
  #281
That's the glue I've been using for a while now. Seems to be the best stuff I've found. I like the fact that it's not as thin as other (water-like) glues. When doing truggy tires I take my dremel and sand/scuff the tire bead pretty good as well as the wheel bead area. Then clean with simple green. I think the power of a truggy motor put more stress on the glue bead area. I think a little more prep for a truggy tire is needed to ensure that the tires stayed glued. Since I've been doing it this way I haven't had any truggy tires come unglued.
Evoking1230 likes this.
Mark K is offline
Old 04-18-2019, 02:11 PM
  #282
I did the same minus the Loctite glue for my Pentangles (truggy tire). Came unglued.
Re-did them with the loctite glue and hoping they hold up. Even put a thin bead around the wheel where it meets the rubber to help "seal" it.
I'll let you know how it goes if the track is open Sunday.
Mark K likes this.
Old 04-22-2019, 12:19 PM
  #283
I can confirm the Loctite glue worked like a charm! Held up just fine for 104 laps while I was out testing yesterday
Mark K and billdelong like this.
