James Racing Tires
#196
No truggy tires in the ebay store?
bummer about the steep shipping prices. I like to support the new guys, but when they cost a bunch more due to shipping, it is hard to.
I found that sweep also have steep slipping prices too ($45us to Canada) which makes them very expensive. I don't want to throw money at proline, but i can't justify spending $45 on shipping for a set of James/Sweep.
#202
Yes and no. They are all supposed to be punched at the factory, but just like with every factory in Asia, sometimes they forget and make mistakes. But so far every set I have used for the last 3 months have had holes in them. The simple thing to do is just check for holes before using and punch if needed.
#204
Suspended
James Tire Track Conditions
Ok so trying to put this together. What's the general consensus of tire to use regarding track condition? I'm just going to assume all tires would be in SS compound
Wasper
Defender
I -Block
Dot Evo
Y-Zip
Revenger
Super Cross
Wasper
Defender
I -Block
Dot Evo
Y-Zip
Revenger
Super Cross
#206
Y-Zip (Blockade)- Blue grooves, low dust
Dot Evo (Hole Shot/Bow Tie)- All conditions - best on wet or dusty tracks
#207
Tech Legend
Picked up in SS compound the Dot Evo, Revenger, and Defender based on some reading here.
Really liked the Revenger for our conditions, went from skating when trying to break last race with a variety of my AKA and proline tires to actually being able to make the turn.
Went with premounts, and they worked quite well. Also wear after a 20 minute main in Nitro buggy was very little for a soft compound (Defenders) and same on the revengers in 1/8 E buggy from a 10 minute main. very happy with the tires, may try the I-Block next and possibly some soft compound tires.
#209
Pentangle's are working for me on just about every condition on a smooth prepped track from watered (light fluff on the edges) to dry/dusty as well as grooved up... they also wear a lot longer when compared to ProLine Electroshot and Buckshot, I get comparable lap times with the M3 compounds from ProLine too, some days the M3's might run a pinch faster and other days (depending on temps) the James Soft compound will run faster. No such thing as 1 compound that works perfect in ALL temps.
#210
I think I'm going to pick up a pair to run at Mikes when I start racing this eTruggy :-)
