Mugen MBX7R
#31
now release an eco version
#32
save yourself any hassle and get an os motor like a xz-b. nova rossi engines are good but they take forever to break in and dont tune as easy as an os engine. go for high torque servos on steering and throttle. having a super fast servo on the throttle can lead to tuning headaches, the carb opening to quick...you need torque for the brakes, a lot of torque.
#33
#34
+1 So am I in the right range of engine with the 4 ports, 3.5cc, and .21? Is the plus .21-4 Btt and Keep off .21-4 the same? Also what torque and speed am I looking for on the throttle servo? I use savox 2274sg for steering in my electric so I was going to use the same on this one. Has 377oz of torque @ 7.4v and .08 speed.
#36
Yes on the engine.
Don't know much about Savox as I have used futaba, airtronics and kopro. All those have been very good. Quality equipment makes this much more enjoyable. As I always knew my stuff was reliable and well prepared.
#37
Thanks for the advice. Taking notes 📝📋✅
#38
Will this battery pack fit? It is a LiPo 7.4v - Dimensions: 84x30x17mm
http://www.amain.com/LRP-VTEC-2S-Li-...500mAh/p291956
#41
I didn't use the shims either , the gears had a perfect mesh . Ive just thought of another build tip,when you build the servo arm up put a small blob of shoe goo on the end of the tiny bolts that go through the arm . it makes sure it will not come undone when racing , which happened to me once . Also make sure you put the little collets the correct way up or you will find the bottom bolt will rub on your servo. This was covered in the MBX7 thread last year .
#43
#44
