Like Tree85Likes
Mugen MBX7R
    Hide Wikipost
Old 04-11-2017, 02:45 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MBX7R
Last edit by: E1 Diablo
Old 03-19-2018, 12:48 AM
  #3871
tom1974's Avatar
Originally Posted by jkas10 View Post
Bill,
The diff cases do not bolt directly onto the 7r chassis. The 8 shock tower is different to fit the new diff cases, and the new wing mount bolts directly to a series of holes, for height adjustment, on the 8 rear shock tower. So, the easiest way to get all the new stuff to fit on a 7r is to buy an 8 Even if you bought an 8 chassis, you would need to get the 8 steering posts since they are keyed into the chassis, meaning the 7r steering posts are too short. The steering rack top plate is different, the rear chassis brace mount is different, and so on, and so on. There are just too many small changes to make it worth trying to upgrade more than just the suspension arms on your 7r platform.
If you want to modify your 7r just build a bushing to reduce the bearing on the differential tanks mount the ht with conical gear support wing hb + 10mm and you're ok
tom1974 is offline
Old 05-08-2018, 05:06 PM
  #3872
Does any one have part number for cvd dog bone and what easy I need to convert my mbx7r from uni to cvd
MadMick is offline
Old 05-20-2018, 12:10 PM
  #3873
Iím wondering the same thing as well. Anyone have a part number for the rear CVD dog bone? I have a bent left rear drive shaft...
Ratdog is offline
Old 05-21-2018, 02:21 PM
  #3874
Adam Drake's Avatar
E0222
Adam Drake is offline
Old 05-28-2018, 09:46 AM
  #3875
Originally Posted by Adam Drake View Post
E0222
Thanks Adam!
Ratdog is offline
Old 06-09-2018, 05:17 AM
  #3876
Default Fuel tank
Will the tank from mbx7r fit in a mbx6r? It's getting old and I'd like a clunk. 😎
magnushedqvist is offline
Old 08-10-2018, 01:00 PM
  #3877
Trader Rating: 18 (100%+)
Can some please help me, Im building a MUGEN ONROAD SPEEDCAR.
I tried to buy a kit couple months ago and they were all sold out, so I've been buying piece by piece from ebay in kit bags.
I have a MBX7 ECO chassis #E2405
I bought a front upright kit , its from a MBX-8 #MUGE2021. It came with uprights, upright arms, pillowballs and hardware.
I would like to run UNIVERSAL Front AXLES # E2218. Will these axles work with my Upright kit that i have ? MUGE2201?
I also read some uprights can run optional larger 16MM Bearing? What is the Advantage of that or what application is it for? Wondering if it would be better then standard 15MM bearing for my application , just going straight and fast?
Theres a guy on ebay selling # E2219 axles which are for why rear of the car, he claims they work on the front also and that he uses them on his car! Have any of you heard of this or tried it?
If i have wrong parts can you please advise what part #s i need and what size bearing these uprights these uprights hold please. Im starting to wonder if its the rear hubs that hold he larger bearing ? Don't have manual so this has been a pain in the butt and i just found one here at top of page UGH!
spectre is offline
Old 10-17-2018, 11:55 AM
  #3878
Hey everyone just picked up one of these and had some mishaps getting a battery going. I originally purchased the ProTek 5196 battery but the voltage is too high for my receiver - anyone have any suggestions for a NiMH battery that'll fit?
So far I see these options :
https://www.amainhobbies.com/ecopowe...p-5009/p697562
https://www.amainhobbies.com/venom-p...nr1503/p115679
https://www.ebay.com/p/Traxxas-3036-...6035356&chn=ps
I also have a hump pack that I bought as well that doesn't fit perfectly into my revo that I could possibly use? Any ideas?
Solico is offline
Old 10-21-2018, 04:07 AM
  #3879
petersen114's Avatar
I use these. Mainly the Lectron Pro. Both are great batteries at a good price. Never have had an issue with either one of them. They are available on ebay.
petersen114 is offline
Old 10-25-2018, 04:17 AM
  #3880
tom1974's Avatar
Link Life or lipo?
thanks
tom1974 is offline
Old 03-13-2019, 05:28 PM
  #3881
wyrnut's Avatar
Trader Rating: 37 (100%+)
Default MBX7r body
Anybody have a used custom painted MBX7R body they want to sell.
thanks
wyrnut is offline
