Mugen MBX7R
#3406
Please let me know how yours work out. I already have those shafts and the bearing equipped is 8x16. But there is at least a 1mm gap between the outer race of the bearing and the inner diameter of the 2105-b upright. On the inside that is. The 8x16 fits fine in the outside.
http://www.neobuggy.net/2017/02/26/u...-adam-drake-6/
#3407
My buddy just installed the 2105-b on his 7R and had no problem. The 8x16 fit properly. I'm going to call mugen today.
#3408
This is a picture of my buddy's 7R with the 2105-b uprights installed with stock shafts and 8x16 bearing. No fitment issue.
#3410
If you look at the correct 2105-b uprights they are machined to fit the cvds with the larger bearing and then the uni shafts with the 8x16 bearing.
#3412
First picture is of the correct 2105-b upright that accepts either shafts and bearings. Second is of the 2105 uprights the bottom is the one I received probably packaged incorrectly.
#3415
all the club racers/amateurs are screaming for an mbx8 BUT:
maifield triples DNC, battlle wins MONTPELLIER.
so is the mbx7r outdated or not?
#3416
I just spoke to Tech support at mugen racing. The 2105-b uprights are made so you can run the stock shafts with the 8x16 bearing or the cvds with larger bearing. The don't require you to order cvds for them to work. That's directly from them. If you couldn't install the stock shafts and bearings it's because either you accidentally ordered 2105 which is the stock mbx7 cvd front uprights or that your 2105-B front uprights were packaged wrong.
#3417
Ok I got you. I looked closer at your pics where the bearing is seated. I def ordered the 2105-b. I just checked my order. I installed them on both vehicles and I only ran the ebuggy this weekend. They where clearly labeled wrong if this is the case. I'll be checking the nitro when I get home. Thanks for the leg work. I hope this package mislabeling isn't a widespread issue.
#3418
Tech support said it's very possible they were packaged incorrectly. I ordered 2 sets and they were both wrong so it's possible it's plenty of them that are wrong.
#3420
racers are often their own worst enemy in always wanting something new. there are certain brands that understand the average racers desire for "new" and gladly oblige by releasing a sub par product more frequently, and there are the brands that build and develop a sound product over time, i know which one i prefer..
