Like Tree88Likes
Mugen MBX7R
    Hide Wikipost
Old 04-11-2017, 02:45 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MBX7R
Last edit by: E1 Diablo
Old 02-25-2017, 01:47 PM
  #3391
tom1974's Avatar
Originally Posted by TRiN View Post
So you're referring to 'vented' style build with foam compensators (as used on the Losi 2.0) sitting on top of the bladder and a exposed hole in the cap. The bladders remain intact though...
With the emulsion build, you need the bleeder screw as the shock cap will be fully screwed onto the shock body thereby closing the side hole on the cap, then you're bleeding the excess oil out of the 'bleeder screw' hole when the oil and air have emulsified with the pumping action. Once done, seal it up with the cap screw...
Have a look at the Losi 4.0 'emulsion' shock cap and Tekno's shock cap which do the different style shock types with detailed descriptions of each...
https://www.amainhobbies.com/team-lo...243034/p475873
https://www.amainhobbies.com/tekno-r...kr8702/p584726
Damper Types
  • Vented: Use bladder included with TKR6009, omitting the small cap screw, small o-ring, and emulsion o-ring.
  • Non-Vented: Use bladder included with TKR6009, small cap screw, and small o-ring, omitting the emulsion o-ring.
  • Emulsion: Use all items included with TKR8702 (emulsion o-ring, small cap screw and small o-ring).
Versus
Tekno's 'Vented' specific shock cap:-
https://www.amainhobbies.com/tekno-r...kr6003/p231813
Lutz emulsion shock build:-
+ YouTube Video
You Can use hb cap schok
tom1974 is offline
Old 02-25-2017, 03:48 PM
  #3392
rubiconon37's's Avatar
So it's ok that the outer race of the 8x16 bearing is smaller than the inner diameter of the front upright
rubiconon37's is offline
Old 02-25-2017, 06:16 PM
  #3393
MugenDrew's Avatar
Trader Rating: 35 (100%+)
Those are 7 up rites.
MugenDrew is offline
Old 02-25-2017, 07:05 PM
  #3394
They are the E2105-B non trailing front uprights. Listed on Mugens sight as upgrade for the mbx7r. Under hop ups. Do you think they were packaged incorrect? I have another set in the package. I opened them and the fit is the same.
Mugen Seiki Home (English)
Old 02-25-2017, 07:10 PM
  #3395
Sorry for the bad link
Mugen E2105-B - MBX7R Front Non-Trailing Steering Kn | NitroHouse.com
Old 02-25-2017, 07:15 PM
  #3396
BermyDomRepRC's Avatar
Trader Rating: 26 (100%+)
Is the bearing pushed all the way in? I think Mugen Drew is right they might be MBX 7 uprights.
BermyDomRepRC is offline
Old 02-25-2017, 07:23 PM
  #3397
Trader Rating: 20 (100%+)
Yep, MBX7 upright.
MX304 is offline
Old 02-25-2017, 07:33 PM
  #3398
bash bros's Avatar
Yeah they look like part# 2105 for the 7
2105-b can fit also fit the 8x16 bearing on the inside
bash bros is offline
Old 02-25-2017, 08:59 PM
  #3399
Super Moderator
1/8 IC Fan's Avatar
Trader Rating: 85 (100%+)
Guess Drake is running cvd's at the DNC.
1/8 IC Fan is offline
Old 02-26-2017, 05:09 AM
  #3400
The bearing is bottomed out. The package label is 2105-B and according to Mugens sight it says these are for the mbx7r. Also Drake did a video about the inline uprights and 2105-B is the part number. I have 2 new sets and the 8x16 bearing fits the same way in both sets.
Is it possible they were not packaged correctly?
Old 02-26-2017, 07:04 AM
  #3401
BigP's Avatar
HB wing mount on the Mugen MBX-7R
Which one are the fast guys (Ryan Maifield, Adam Drake, ...) using at the moment at the Dirt Nitro Challenge 2017?
HB Racing V2 Wing Mount (Standard) [HBS114414]
HB Racing V2 Wing Mount (+10mm) [HBS114415]
It looks like you just need to cut off the brace at the bottom and bend it a little bit with a heat gun to fit it.
Is the Mugen Wing fitting with the original holes?
Adam Drake is using the PL Lexan wing and Ryan Maifield an unknown wing...
BigP is offline
Old 02-26-2017, 07:25 AM
  #3402
thecatman's Avatar
i have set 2105-B also coming from nitro house. A-mian has "Note: These carriers require the use of the MUGE2218 Universal Driveshafts and 8x16mm Bearings, as used on the MBX7R" on theres. I thought the hubs accepted both sizes of bearings like the rear hubs.
I will post more this week once they come in.
thecatman is offline
Old 02-26-2017, 09:24 AM
  #3403
Please let me know how yours work out. I already have those shafts and the bearing equipped is 8x16. But there is at least a 1mm gap between the outer race of the bearing and the inner diameter of the 2105-b upright. On the inside that is. The 8x16 fits fine in the outside.
Old 02-26-2017, 12:46 PM
  #3404
rider313's Avatar
Trader Rating: 94 (100%+)
Ryan is using a AE B3 wing.
rider313 is offline
Old 02-27-2017, 03:54 AM
  #3405
tom1974's Avatar
Have you link please???
tom1974 is offline
