Like Tree89Likes
Mugen MBX7R
    Hide Wikipost
Old 04-11-2017, 02:45 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MBX7R
Last edit by: E1 Diablo
Old 02-16-2017, 08:13 AM
  #3376
jkas10's Avatar
Trader Rating: 123 (100%+)
Originally Posted by rotor head33 View Post
If you don't drill the cap you can't let the air fully out
DO NOT drill a hole in the top portion of the shock cap if you are going to run emulsion. You will lose all of your shock fluid.
(only a hole low on the side of the cap - thread area - for bleeding the excess fluid out. It will be sealed when the cap is tightened)
jkas10 is offline
Old 02-16-2017, 08:19 AM
  #3377
samuelsonmark71's Avatar
Trader Rating: 22 (100%+)
Or just use these: https://www.amainhobbies.com/hb-raci...114745/p447420
pballer2777 likes this.
samuelsonmark71 is offline
Old 02-16-2017, 11:08 AM
  #3378
jkas10's Avatar
Originally Posted by maximuspowell View Post
does anybody know where to buy air filters beside amain?
Dialed RC Hobbies:
http://dialedhobbies.com/accessories...x7-detail.html
or preoiled:
http://dialedhobbies.com/accessories...78-detail.html
jkas10 is offline
Old 02-16-2017, 12:12 PM
  #3379
Ummmm no. How would you lose the fluid when it has a screw in it? How on earth can you build an emulsion shock with removing 100% of the air?
rotor head33 is offline
Old 02-16-2017, 12:57 PM
  #3380
jkas10's Avatar
I am referring to a hole without a screw in it. Like the Losi 2.0 bladder shock trick. You would drill a hole and leave it open. It was to allow the air behind the bladder to exit, and enter, through to keep from developing too much air pressure behind the bladder.
Like I said, only use a fluid bleeder hole with an emulsion shock.
jkas10 is offline
Old 02-16-2017, 01:43 PM
  #3381
Exclamation
So you're referring to 'vented' style build with foam compensators (as used on the Losi 2.0) sitting on top of the bladder and a exposed hole in the cap. The bladders remain intact though...
With the emulsion build, you need the bleeder screw as the shock cap will be fully screwed onto the shock body thereby closing the side hole on the cap, then you're bleeding the excess oil out of the 'bleeder screw' hole when the oil and air have emulsified with the pumping action. Once done, seal it up with the cap screw...
Have a look at the Losi 4.0 'emulsion' shock cap and Tekno's shock cap which do the different style shock types with detailed descriptions of each...
https://www.amainhobbies.com/team-lo...243034/p475873
https://www.amainhobbies.com/tekno-r...kr8702/p584726
Damper Types
        Versus
        Tekno's 'Vented' specific shock cap:-
        https://www.amainhobbies.com/tekno-r...kr6003/p231813
        Lutz emulsion shock build:-
        + YouTube Video
        jkas10 likes this.
        TRiN is offline
        Old 02-20-2017, 05:44 PM
          #3382
        Lightbulb Trailing axle vs non-trailing axle
        Hello,
        Recently, when I was trying to get familiar with the theory behind trailing axles I came across this channel on YT: @doctormosfet.
        I watched most of his setup videos and the guy seems to know what he's talking about (at least I haven't found any statements that were suspicious for me ).
        Now, the problem is that with regard to trailing axles he's saying the exact opposite thing in comparison to Adam Drake. It got me thinking.
        Have anyone dug deeper into this topic and could comment on this?
        You can find both videos here:
        @doctormosfet
        @Adam
        I would rather lean towards Adam's version. My opinion is that in doctormosfet's video the wrong conclusion comes at 3:53 when he traces out the arcs. I suppose that the fact that with non-trailing axle this arc is sharper it suggested that the turning radius of the whole car would be sharper as well. That's not the case in my opinion.
        I couldn't sleep so I drew the geometry
        Ok, that's it for the theory! Seems like Adam is right.
        Now I'm curious if you agree + what are your personal feelings from testing both
        Donat is offline
        Old 02-21-2017, 12:30 AM
          #3383
        Trader Rating: 32 (100%+)
        what is the difference between front upright E2129 & E2105??
        any visible mark or print on the upright to show which is which??
        hobbs is offline
        Old 02-22-2017, 06:39 AM
          #3384
        Inline and Trailing?
        Adam Drake probably has a video for this. Youtube is your friend
        https://www.youtube.com/watch?v=wMLngPEVY-A
        Chris Reilly is offline
        Old 02-22-2017, 11:19 AM
          #3385
        tom1974's Avatar
        The difference are ball-bearing...
        E2129 ball bearing are both 8x16x5
        tom1974 is offline
        Old 02-24-2017, 08:05 AM
          #3386
        Default Blank shock pistons for MBX7
        Does anyone know a direct fit blank shock pistons for the MBX7 (not R)?
        Seems like Mugen is only making those for the new 16mm shocks...
        Preferably, I'm looking for ones with predrilled marks.
        Donat is offline
        Old 02-25-2017, 10:46 AM
          #3387
        rubiconon37's's Avatar
        I'm hoping someone can help me. I'm changing over to the non trailing front uprights on my mbx7r. The inner bearing on the universal is too small on the outside diameter. I'm trying to install the stock 8x16 into the E2105-B upright and it's too small. Any help would be appreciated.
        rubiconon37's is offline
        Old 02-25-2017, 12:42 PM
          #3388
        According to this, you need the other upright or a smaller bearing.
        My ST-RR EVO is offline
        Old 02-25-2017, 01:21 PM
          #3389
        The stock bearing get is a 8x16. When you put that bearing into the E2105-B upright it appears to be too small. I'm wondering if anyone else has run into this problem before? Or is it possible mine weren't machined correctly.
        Old 02-25-2017, 01:43 PM
          #3390
        tom1974's Avatar
        Yes man..... ball bearing is 8x16x5.....
        tom1974 is offline
