Like Tree88Likes
Mugen MBX7R
    Hide Wikipost
Old 04-11-2017, 02:45 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MBX7R
Last edit by: E1 Diablo
Old 01-27-2017, 06:52 AM
  #3346
https://www.amainhobbies.com/team-as...c81038/p443680
these are what i use
maximuspowell is offline
Old 01-27-2017, 07:31 AM
  #3347
samuelsonmark71's Avatar
Trader Rating: 22 (100%+)
I run the Tekno ones, but pretty much the same thing:
https://www.amainhobbies.com/tekno-r...kr5368/p510046
samuelsonmark71 is offline
Old 01-27-2017, 08:17 AM
  #3348
Trader Rating: 21 (100%+)
Can I use gas lines instead of the spring? Or will it give it a spongy type feeling in the brakes? I think if your throttle servo has enough tq, it wouldn't be a big deal.
Thoughts?
NoobRacer is offline
Old 01-27-2017, 08:46 AM
  #3349
I thought. If you are pressed for it, you can always cut down some click pen springs (I did that on my first MBX7R)
Old 01-27-2017, 08:49 PM
  #3350
stanleyw808's Avatar
Hello NoobRacer,
I would like think that Gas Lines or Fuel Lines would be somewhat to "Stiff" for this application.
Cutting a Pen Spring would not be the best thing either because sometimes the end of the spring could go inside the gap between the screw and the Brake Plate opening. If the uncoiled end of the spring go into the gap it could jam the brake system movement.
The best is still a proper Brake Return Spring with a both end coiled properly.
Cheers..
Thoughts?
stanleyw808 is offline
Old 01-28-2017, 08:08 AM
  #3351
tom1974's Avatar
https://www.dropbox.com/s/xv4zydq2ho...A0062.mp4?dl=0
tom1974 is offline
  #3352
tom1974's Avatar
new differential
tom1974 is offline
Old 01-31-2017, 09:15 AM
  #3353
New down-force wings coming out from ProStar:
http://www.liverc.com/news/new_produ...ipped_buggies/
Old 01-31-2017, 05:44 PM
  #3354
What are the reasons for a squeaky steering? I removed the servo arm, cleaned the steering components and checked for binding. Is it the Servo saver??
rcindia is offline
Old 02-01-2017, 03:08 PM
  #3355
curacing2's Avatar
It can be the pillowballs a bit tight or dust in them
curacing2 is offline
Old 02-01-2017, 05:49 PM
  #3356
9 times out of 10 it's dusty pillow balls. Other high possibility is dirty pins
rotor head33 is offline
Old 02-04-2017, 03:23 AM
  #3357
Trader Rating: 32 (100%+)
Hi,
Few pages back, there is a mention of using HB wing mount.
Anyone has the part number of the HB wing mount??
Is it a direct fit to MBX7r??? any mod required??
About shock boots, what other brands of shock boots can I use besides the original???
Thanks.
hobbs is offline
Old 02-05-2017, 10:30 AM
  #3358
Most people I know use normal balloons instead of the original shock boots if they don't want to spend the money for the original spare parts.
Millord is offline
Old 02-05-2017, 12:45 PM
  #3359
tom1974's Avatar
Hb 114415
tom1974 is offline
Old 02-05-2017, 12:46 PM
  #3360
tom1974's Avatar
Can i have info new differential????
Which oil your use???
tom1974 is offline
