Like Tree89Likes
Mugen MBX7R
    Hide Wikipost
Old 04-11-2017, 02:45 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MBX7R
Last edit by: E1 Diablo
Old 06-01-2016, 10:00 PM
  #2476
YANMAN's Avatar
Trader Rating: 41 (100%+)
Does anyone have a link to the latest greatest setup. I am building a kit for someone and they want me to put the latest greatest on the car. I told him Kit setup but you know if you have Drakes setup you will drive like Drake. Lol
YANMAN is offline
Old 06-01-2016, 10:23 PM
  #2477
Maybe state what kind of track y'all will be running on. I have a bunch of drakes setups, don't use any of them since they don't work for my track though.
rotor head33 is offline
Old 06-02-2016, 08:23 AM
  #2478
YANMAN's Avatar
Thornhill. It's for the Roar Nats.
YANMAN is offline
Old 06-02-2016, 06:25 PM
  #2479
RCBuster's Avatar
Trader Rating: 25 (100%+)
Here's a link:
http://www.mugenracing.com/setup-sheets/
Good luck at the Nats
RCBuster is offline
Old 06-04-2016, 01:50 PM
  #2480
Default mugen mbx7r
hi guys what's the handling difference on the rear hub where the two holes are at the bottom. mine still is in the kit setup on the top hole. what happens if i change to the lower hole.
TIM.L.BARNETT is offline
Old 06-04-2016, 05:57 PM
  #2481
Trader Rating: 40 (100%+)
Adam Drake has a good video on rear hub positions:
Adam Drake from Mugen Seiki Racing talk about Rear Hub position
Rick S is offline
Old 06-08-2016, 05:42 PM
  #2482
soooo.... any speculation on the new mbx8?
Old 06-08-2016, 07:00 PM
  #2483
hairymuffin's Avatar
Trader Rating: 100 (100%+)
Nope, mugen is really good at keeping thing hush hush
hairymuffin is offline
Old 06-08-2016, 07:01 PM
  #2484
I know I was surprised to see neo buggy releasing an article
Old 06-10-2016, 10:03 AM
  #2485
1/8 IC Fan's Avatar
Trader Rating: 91 (100%+)
Curious, has anyone replaces front hub bearings lately? I am looking to order a full set for the buggy, but am wondering should I order standard rubber shielded bearings, or splurge for a set of ceramics? Personnaly, I have never had much issue with rubber shielded standard bearings, yet wonder giver the change to universals, and the smaller bearings in the R series cars what anyone else might have found out.
Is there more wear and tear than the previous non R platform, or same?
Oh, the conditions I run in are fairly dusty and humid. Some times even during rain.
1/8 IC Fan is offline
Old 06-10-2016, 10:21 AM
  #2486
Get the mugen nmb bearings, very free spinning
Old 06-10-2016, 11:14 AM
  #2487
bash bros's Avatar
The NMB's look nice haven't tried them yet but some of the team drivers run them.
The mp9 kyosho bearings work great too. I bought a set off dollar hobbyz a while back. They seem like plain old 688zz metal shield bearings but they're very smooth and free. It seems like they use a oil or lighter grease or something.
I've been running the plain rubber shield bearings degreased and re-lubed with a drop of bearing oil. I've had good luck so far even on a really dusty track. Oiled bearings along with center uni's really frees up the drivetrain. The 8x16x5 bearings do seem to last a lot longer and need less maintenance than larger bearings used with the cvd's.
bash bros is offline
Old 06-12-2016, 12:48 PM
  #2488
1/8 IC Fan's Avatar
Thanks, I'll give them a shot.
Old 06-13-2016, 11:45 AM
  #2489
You will like the NMB bearings. Not only are they very free spinning, they last longer too... Definitly an improvement over the older bearings.
thommi is offline
Old 06-13-2016, 11:47 AM
  #2490
Super Moderator
Trader Rating: 21 (100%+)
In case you guys didn't notice it, I've created the Wiki for this thread. Similar to the old '1st page' posts, but now it appears at the top of every page.
Anyone can edit it, but just keep in mind that EVERY edit is recorded and we can see who did it. Abusing it will result in a forum ban.
My suggestion is that if you have a new item you want to post on the Wiki and aren't sure if you should, just post it in the normal part of the thread and ask. If you see a majority in agreement, post it.
Bob Barry is offline
