sticky pivot balls >
sticky pivot balls
sticky pivot balls
Old 10-20-2014, 06:01 AM
Default sticky pivot balls
Im having an issue with the pivot balls in my caster buggy. They are kinda sticky and its making the steering shudder and just doesnt seem right. Are the balls supposed to have some kind of coating on them? I have the nuts tight so there is no play but notso tight that they bind. Im not sure what the issue is....i put a bit of oil in there but its not really helping anymore. What to do?
bksrt is offline
Old 10-20-2014, 06:11 AM
Roelof's Avatar
with a fresh building I do screw the play a bit tight and then I move the pivot ball arround. This will shape the plastics to the pivot ball and after that I set the play normal.
Roelof is offline
Old 10-20-2014, 07:17 AM
adrictan's Avatar
Don't put oil in them. You'll end up with dirt and sand in them which will become sticky with the oil. Maybe that's wht happened in the first place.
adrictan is offline
Old 10-20-2014, 08:40 AM
Frank L's Avatar
Trader Rating: 148 (100%+)
I blow them out with air and use some kind of prep/ shine (the upgrade stuff is my fav) squirt it in there and be done with it.
If they at binding take them out and clean them and the plastic too. Depends on driving conditions and type of dirt they may have to be cleaned me often than others.
Frank L is offline
Old 10-20-2014, 10:34 AM
So is there supposed to be a bit of play in them then? I could likely back the screws out a bit and it would be fine. Ill clean out the oil as well of course. I didint think there was supposed to be any play in there thats why i tightened them in the first place lol
bksrt is offline
Old 10-20-2014, 11:23 AM
You absolutely need play. You will have to experiment as to how much because each car brand and even the dirt makes a difference.
3DRCRACER is offline
Old 10-20-2014, 04:17 PM
Hoese37's Avatar
Get new bushings. Or also get some metal polishing compound and chuck the balls up in a drill and polish them till they are mirror like.
Hoese37 is offline
Old 10-20-2014, 07:43 PM
can you post a picture of the pivot ball and the area you're talking about?
My ST-RR EVO is offline
Old 10-21-2014, 05:31 AM
Itll take me a few days probably but ill take some pics. Im super busy this week plus ill probably forget but i will get some lol.
I figured they would have a graphite/teflon coating of some kind. The ones in my car are already pretty much mirror finish but im starting to think maybe i have too much pressure on them. I havent had a chance to do anything with it yet.
bksrt is offline
