HELP in new to nitro and my engine is not starting well >
Old 07-21-2014, 02:35 PM
Default HELP in new to nitro and my engine is not starting well
just broke in a dynamite mach 2 .19 and it was starting great when i was breaking it in and a few times after that. now it takes for ever to start(eazy start on a revo just turns motor have a glow plug igniter) but now it takes for ever to start like 5 min of holding the exhaust closed then when it does fire up it will go but if i get just over 1/2 throttle it just dies please help me!!!
reclaimer429 is offline
Old 07-21-2014, 03:18 PM
i got it to start but the temp shot up to 310 after abut 5 min of running and now its hard to start again im lost
Old 07-21-2014, 04:53 PM
nitroexpress's Avatar
http://www.youtube.com/watch?v=fWvlEAWVBEM
nitroexpress is offline
Old 07-21-2014, 05:34 PM
JsK
JsK's Avatar
Did you change the glow plug after breakin? Also be careful turning it over for prolonged periods with that easy start. Let it cool down for a few minutes in between attempts. It's very easy to overheat the little easy start motor.
JsK is offline
Old 07-22-2014, 08:36 AM
i have not changed the glow plug. can i run 3.3 glow plugs in the dynamite engine? im guessing no
Old 07-23-2014, 06:16 PM
wow so much help here!!! thank everyone!!
Old 08-13-2014, 07:31 PM
Suspended
I'm no expert but every nitro engine iveowed got harder to start After break in. And setting the tune good.
The trick is learning how to start them. 3-4 seconds covering the exhaust outlet WITHOUT the glow igniter. I usually do it till I can hear the starter box speed up slightly. mine usually fires right up after priming it this way.
mtpocketsracing is offline
Old 08-13-2014, 10:08 PM
I Wheelie A LOT's Avatar
Trader Rating: 15 (100%+)
+1 Glow plugs usually die out during break in sessions or after. I would suggest a new plug before you play with the needles. You may risk the chance of completely messing up the tune if you do, and will just end up chasing it around.
I'm not so sure, but the MC59 would probably work with your engine. It's a hot plug so it'll make tuning a bit easier. Good luck!
http://www3.towerhobbies.com/cgi-bin...P?I=LXRA06&P=8
I Wheelie A LOT is offline
