Stock gearing on RC10GT? >
Old 07-15-2014, 12:45 AM
Ogawa_Seiki671's Avatar
Default Stock gearing on RC10GT?
I have a RC10GT with the Os max .12cv whats the stock gearing, I also would like to know whats a good gearing for top speed. I have a 15 clutchbell and the 66 tooth spur gear
Ogawa_Seiki671 is offline
Old 07-15-2014, 06:14 AM
Some came with 16 x 66, & later ones, including the factory team, came with 15 x 66
Check out the GT gearing guide I attached.
File Type: pdf
Evoking1230 is offline
Old 07-15-2014, 06:19 AM
you didnt mention what and/or where you need the top speed for. Is it for a long straightaway on your track, or just want to go faster in the parking lot/baseball field.
If youre looking for speed, a good tune, a tuned pipe tuned for the top end. The 16/66 combo should be good for up to 40mph depending on motor and tune.
If its for the track, same as above but make sure you have the right tires and setup under it first, no point in increasing top speed if you cant plant the rear end on corner exit
Old 07-21-2014, 05:28 AM
[QUOTE=Evoking1230;13401777] As I said os.12cv and want top end, Im running 15/66 getting 32mph good tune and 20%
Old 07-21-2014, 06:25 AM
How's your slipper clutch? Is it not staying locked up under high load in full pull?
Tug Driver is offline
