agama a8t diff
Old 07-14-2014, 07:09 PM
snoborder73's Avatar
Default agama a8t diff
hi! wondering if anyone has experience in rebuilding agama a8t rear diffs? am replacing ring,pinion,bearings in diff! anything i need to know? thanks!
snoborder73 is offline
Old 07-25-2014, 04:29 PM
I have about a gallon on my truck and no diff or bearing issues. I do however take the extra time to shim both ring and pinion for the front and rear diffs. Hope this helps
bc7705 is offline
Old 07-25-2014, 04:54 PM
nitroexpress's Avatar
All gear type diffs are pretty much the same. So what are your questions?
http://www.youtube.com/watch?v=DbOfV5J5Z0k
nitroexpress is offline
Old 07-25-2014, 09:31 PM
Default nitro truggy diffs
my questions would be: am assembling front,mid,rear diffs factory way.heard i should shim diffs after a tank of gas!? where am i putting shims? if i am correct,i am tightening ring gear to pinion,for after break in. correct? shimming procedure for all diffs.? thanks!
Old 07-25-2014, 10:27 PM
http://www.youtube.com/watch?v=Tm1V5cdMq5A
Do you have the user manual?
Old 07-26-2014, 09:49 AM
Frank L's Avatar
Trader Rating: 148 (100%+)
Shim from truck to truck will be different. You want just a tic of play - add shims on the correct side to accomplish this.
Frank L is offline
Old 07-28-2014, 09:34 AM
BillyT.'s Avatar
Start with two on left, one on right(always pushing the ring gear onto the pinion). Between the bulkhead bearing carrier and the outer race of the bearing.
Never had issues when shimmed this way. Tight is better than loose. (huh huh)
You will actually want it to be a little notchy when brand new. They will wear in and give you good life.
BillyT. is offline
