3 needle carb
Old 07-14-2014, 01:18 PM
Jaymancd's Avatar
Default 3 needle carb
Hi all, I am sure that someone has asked this before but what is the 3rd needle for? I have a newer OS that has a 3 needle carb on it, I know what the low and high speed needles are for I just cant figure out what the 3rd is for. any help would be appreciated.
Jaymancd is offline
Old 07-14-2014, 01:24 PM
it's for mid range adjustment, not for the rookie tuner they can be a real pain.
2fastphil is offline
Old 07-14-2014, 07:31 PM
Jerm13's Avatar
Trader Rating: 36 (100%+)
What he said. Dont touch it. Get some Grey RTV and put a dab over it so you cant see it. This will make you forget it is there and then you wont have issues
Jerm13 is offline
Old 07-14-2014, 07:40 PM
If you get to the point that you can actually tune the 3rd needle it's used to adjust the spray bar in the carb throat. When you tune the 3rd needle, you turn it in sequence with the low range. What that means is you turn the mid 1/4 turn and the low 1/4 turn in the same direction. What your actually doing is moving the spray bar in the carb throat.
Like everyone else says, leave it alone and forget about it. 99.9% of us aren't good enough to notice the change it will make.
Tug Driver is offline
Old 07-14-2014, 09:12 PM
Jaymancd's Avatar
Ok will do. I am somewhat inexperienced in tuning and didn't want to screw something up. glad I asked. thanks
Jaymancd is offline
