motor sutting for 2 years with fuel and no after run oil...
motor sitting for 2 years with fuel and no after run oil...
What do I need to do before I start it up again??
Depends on where it was sitting! But is prob toast!! Or what's going to happen is you'll start it and it will run, prob ok, but it prob won't last more than a gallon or 2......i could be wrong .....goodluck
i put wd40 inside and leave it there for a few minutes and then i use my air compressor to remove excessive and new spark plug depends of the engine my engines are o.s good quality the start like new
Putting WD40 in there is a horrible idea! Just put some caster oil (an oil that the engine can burn) in the glow plug hole and spin the engine back and forth until it feels smooth again. Should fire right up, but you'll need to put a new glow plug in it as soon as the engine cleans itself out with the fuel.
What's castor oil
If the engine is stuck it's because the fuel evaporated and the sticky oil tacked everything together. If you flood the engine with fuel again it will loosen everything back up. I had a force .28 sit for 4 years. The piston was stuck and the pull start pin was stuck in it's hole. I heated the pin with a small torch and it built pressure behind it (like a piston) and forced it out to sheer I could clean it up. The fuel freed the stuck piston and it rolled right over.
It's not uncommon for an engine even properly stored with after run oil to lock up after a few years. I have a few aircraft engines that are locked up solid, carb barrel and all. They are next on my list of engines to get going, but will take a little bit more tinkering.
Using WD40 to free an engine is perfectly fine. It can even be used as an after run oil. Just flush the bearings out with it or some new fuel. You could even let it soak for an hour or two. Just remember to coat everything on some sort of light oil before you fire it up again for the first time.
I actually run a rb ws7 that sat for 6 years (maybe more) . All I did was take off the back plate , and the glow plug and run a can of "mass air cleaner" from the auto parts store through it till it freed up. Then , I used mobile 1 0-20 to lube things on start up . Runs great ...
You can just use the fuel your going to use and let it sit in the engine. Take the plug out and fill up the engine thro the carb and let it sit. After about 30mins you can lightly turn the crank to help work the dried up oil loose. Let it continue to sit for another 30mins then flush with new fuel a few times and good to go.
The only other thing is you might have oil build up in the needles so you could take the carb off and soak it in fuel too
ive had this happen several times. what i do is remove the head, bsckplate, and carb and let soak in nitro submerged for a day. Reassemble, seal, and voila. hope it works and runs!
