O.S motor question >
O.S motor question
O.S motor question
Old 06-11-2014, 08:57 PM
TheRcworld101's Avatar
Cool O.S motor question
Hey there guys I want to get a little O.S motor question answered I will be running an mbx7 nitro soon and I will be running O.S and I wanted to know what pipe Hara uses the O.S. T-2090SC or the O.S T-2060SC??? thanks!
TheRcworld101 is offline
Old 06-12-2014, 01:07 AM
morgoth's Avatar
OS 2090 for the XZB Speeds. OS 2060 for the VZB speeds.
morgoth is offline
Old 06-12-2014, 07:39 AM
PTP Racing's Avatar
Silly question whats the difference? I mean what power range is the 2090 better then 2060? I have the 2060 I'm planning on using with mine just wondering if its worth it to get the 2090.
PTP Racing is offline
Old 06-12-2014, 09:27 AM
Frank L's Avatar
Trader Rating: 148 (100%+)
The 2090 let's the xz based engines open up more on the top and makes them a little more responsive on the bottom to. Also somehow it adds a little mileage 20-30 sec. For that engine the 2090 is the pipe you want. The 2060/2090 header is the same and you can usually find the pipe without the header. Saves a few $$
Frank L is offline
Old 06-12-2014, 10:47 AM
alexzone007's Avatar
tytessman uses 2090 witht xz-b speed
alexzone007 is offline
Old 06-12-2014, 04:23 PM
I have been using it and noticed what Frank says, better on bottom and top. I only get around 8 minutes though at races you have been also
USMC STONE 1 is offline
Old 06-13-2014, 01:13 AM
Trader Rating: 127 (100%+)
I have a 2090 for sale thats barely used. Has just really fine scratches on it but no dents and still looks almost new....PM me if anyone is interested
Neesh is offline
Old 06-13-2014, 01:17 AM
morgoth's Avatar
The XZB engines are long stroke engines. The older VZB engines are short stroke engines. The 2090 is made for the XZB long stroke engines and the 2060 pipe is made for the short stroke VZB engines.
Yes, you can use the 2060 on the XZB and vice versa and the engine will run, but you won't get the maximum out of it.
morgoth is offline
Old 06-19-2014, 10:27 PM
RcRick's Avatar
Trader Rating: 19 (100%+)
Anyone Know what wrench size the head bolts are on a VZB speed?
RcRick is offline
Old 06-20-2014, 01:02 AM
He uses the os 2060, most of the time.
kyosho28 is offline
