CY26cc vs 30.5cc Rovan 4bolt +2mm >
Old 06-11-2014, 02:12 PM
Default CY26cc vs 30.5cc Rovan 4bolt +2mm
Hi mates, I had a worn out CY 26cc and decided to install the Rovan 4bolt 30.5cc +2mm upgrade kit. Myself, My brother and my dad have the Dominator pipe on our HPI Bajas. The strange thing is that their CY26 is pulling wheelies and seems to have more power, and my 30.5 seems to be underpowered at the launching stage, and not revving as high. There seems to be some short juicy power only at the mid revs. We all have the WT668B, same gearing, same tires, same fuel, same dominator and same 8k clutch. Their launching is hard and sounds aggressive. Mine launches underpowered and opens up in the mid revs, but still not faster then theirs.
The engine is on 2nd tank ...I have no leaks, good compression, white spark, new NGK plug.
Do you have any ideas what this could be? I am frustrated! I pretend to have more power due to the larger bore and longer stroke! Thanks in Advance
I would really appreciate if you hint me up! :P
nuclemike is offline
Old 06-11-2014, 06:31 PM
frewster's Avatar
It would be best to post in the large scale forum. This section is for nitro.
frewster is offline
Old 06-11-2014, 10:58 PM
wmazz's Avatar
Stroker cranks are not an easy bolt on power boost. You will make better power
with the stock crank.
If you to say that you run 5% nitro in your engine, then you are in the right section
I certainly did for my sponsored Goped Racers.
Bill M.
wmazz is offline
