nitro hawk transmission gears >
Old 06-11-2014, 02:32 AM
Default nitro hawk transmission gears
Quick question about gears
I want to upgrade all my gears to run a stronger motor
I noticed that the hopup idler gear (1996x) is aluminum, while new planetary gear diff (2388x) is steel, and stock top drive gear is steel as well.
wouldn't there be a problem running an aluminum idler with steel gears?
Is there a steel idler I can use?
Dynikus is offline
Old 06-14-2014, 07:45 PM
Nitro_Hawk's Avatar
Just saw this, there is a steel idler gear for the nitro hawk, I believe it's the same as in the rustler vxl or slash.
I also got the aluminum one back in the day and retired the Nitro Hawk years later with the gear still in there and intact, never had a problem with the transmission while running a OS .18.
Nitro_Hawk is offline
