Can I use mp9 swing shaft in Mp777 wc? >
Old 06-02-2014, 09:45 AM
Default Can I use mp9 swing shaft in Mp777 wc?
Hi Like above Can I run the mp9 swing shaft on my mp777 ?
Asking because I snapped my on the race, and my local hobby shop only stores this mp9 KYOSHO UNIVERSAL SWING SHAFT HD 91MM http://www.wheelspinmodels.co.uk/i/223521/
will it work it has same bearing size but it is 91mm (the stock mp777 has 90.7mm)
Need quick answer Please.
Thanks you.
Mr.NitroBurner is offline
Old 06-02-2014, 10:18 AM
It shouldn't be a problem. The MP777 shafts fit great on the MP9 and the 0.3mm difference should be negligible going the other way.
-Kane
Kane-o is offline
Old 06-02-2014, 12:31 PM
ok thanks so i will put it on order thanks
Old 06-04-2014, 09:53 AM
Did anyone try it before?
