Stumped on set up >
Stumped on set up
Stumped on set up
Old 06-01-2014, 07:39 PM
portyansky's Avatar
Trader Rating: 54 (100%+)
Default Stumped on set up
Rear:
Long upper link
Upper hole on shock tower
Upper hole on hub
3deg camber
5k
30wt
Blue spring
I should have a ton of rear traction, but the rear slides around. I can't get this rc8.2 figured out. Should I go to 3k? Stumped...
Edit: lose traction on power
portyansky is offline
Old 06-01-2014, 09:35 PM
jkas10's Avatar
Trader Rating: 123 (100%+)
Originally Posted by portyansky View Post
Rear:
Long upper link
Upper hole on hub
3deg camber
5k
30wt
Blue spring
Hard to say without knowing the rest of the setup and track conditions. However, if you are up on the tower AND the hub, that counter-acts each adjustment. I would go low inner hole on tower and middle hole on hub for length. Sometimes, what feels loose coming off a corner is actually tight and you finally get the car to snap free on corner exit. Lowering the link should free the rear of the car up to rotate throughout the corner and drive straight off. You may want to move your hub forward on the rear arm to transfer weight to the rear quicker on acceleration. 554 with diffs or 553 if really tight track.
jkas10 is offline
Old 06-01-2014, 09:46 PM
JasonR/C's Avatar
I had that car, then I bought a serpent and it fixed all my issues
JasonR/C is offline
Old 06-03-2014, 12:33 AM
Rear:
Long upper link
Upper hole on hub
3deg camber
5k
30wt
Blue spring
hey boss when you say slides around....when?
on throttle or off?
and what diff oils pistons and springs.......that car works just fine!
Jason Snyder is offline
Old 06-03-2014, 01:41 AM
JsK
JsK's Avatar
Rear:
Long upper link
Upper hole on hub
3deg camber
5k
30wt
Blue spring
PM Wayne screen name Razathorn. He has some good ideas for the 8.2
JsK is offline
