Engine dies when 1/4" fuel left in tank. >
Old 05-25-2014, 10:09 PM
mercfocus's Avatar
Default Engine dies when 1/4" fuel left in tank.
Starting yesterday, my engine started dying when it gets down to about a 1/4" of fuel left in it. I drove it today just to see this again and it's really consistent.
It's always right at that level and if I keep the fueling it up and not letting it get down that low, it doesn't die.
It fires right up and runs good even at that level without refueling.
Is there something there that needs to be cleaned or flushed?
It's an OFNA LX2 with a Hyper .21 8 port.
The fuel I've been running and just finished the whole gallon today is Odonnels 20%.
I just bought it less than a month ago but I think it's old and maybe that's why I'm getting what I'm getting if not a tank/filter issue. I don't use filters any more, just the one that's in the tank.
Attached Thumbnails Engine dies when 1/4" fuel left in tank.-dsc06661.jpg
mercfocus is offline
Old 05-25-2014, 10:15 PM
Jaz240's Avatar
Trader Rating: 52 (100%+)
Check your pressure lines and clean out your pipe. It sounds like your tank is not getting enough pressure.
Jaz240 is offline
Old 05-26-2014, 01:00 AM
meis's Avatar
you can try blowing the pressure line and check if the fuel is coming out when the fuel is that low. You can even test it with water, but make sure you clean it with fuel first before running again.
meis is offline
Old 05-28-2014, 06:08 AM
Trader Rating: 18 (100%+)
Could try replacing or if possible tightning the oring in the lid of the tank probably just not getting a good seal
nitromugen86 is offline
Old 05-28-2014, 07:12 AM
Trader Rating: 20 (100%+)
Air leak… most likely the tank.
NocturnalNitro is offline
Old 05-28-2014, 07:46 AM
Same thing happened to me this past weekend - Changed tank and line and was good.
token is offline
Old 05-28-2014, 07:59 AM
I experienced the same thing a month ago with an Ofna Hyper 7. I had an air leak at the tank lid. I tightened up the screw under the cap, putting a little more pressure on the O-ring, which solved the problem. I also shortened the pressure line from the pipe to the tank. Thanks to the contributors in this forum who helped troubleshoot/resolve the problem
dcb504 is offline
