Trouble with BUKU clutch. >
Old 05-22-2014, 09:19 PM
Default Trouble with BUKU clutch.
Hi guys, I have a losi 8ight t 2.0 with a clocked nova 28-5, combined with a novarossi 9886 SS pipe and 41001 header, my gearing is 15/48, and I cant seem to get my clutch set up properly I get temps of excess in the 340 range. .I truly believe I need to gear down, im using stock wheels which are 135mm. I've recently gone back to the stock clutch with a 13t clutch bell and I feel im doing a lot better. Ill give the buku another shot witj a 13t clutch bell. Any thoughts. On this? Thank! -Adrian
Element90001 is offline
Old 05-22-2014, 09:23 PM
nickdawg18's Avatar
Trader Rating: 33 (100%+)
Use a new bell with your buku. Don't let grease get on the shoes either.
nickdawg18 is offline
Old 05-22-2014, 09:25 PM
kaptain crash's Avatar
Trader Rating: 46 (100%+)
why did you bump it from a 13t to a 15t? should run the same gearing might fry the shoe's with bumping it up to a 15t
thought the stock gearing for the truggy was 13/50
kaptain crash is offline
Old 05-22-2014, 09:29 PM
curacing2's Avatar
You would have als glazed up the shoes from over gearing with the 15T bell, Yes buy a new bell and sand off the shoes back to the clean alloy, start with the adjuster grubscrew about a turn in from flush and set from there.
curacing2 is offline
Old 05-22-2014, 09:43 PM
new vented clutch bell. lightly sand off the clutch shoes with fine sand paper if they are glazed
NOvarossi is offline
Old 05-22-2014, 11:32 PM
Trader Rating: 42 (98%+)
I'm not sure if you are supposed to sand them or not but I do know that if you think you got bearing grease on them you need to heat them up with a heat gun and it will make whatever residue come out. I also think you need to use denatured alcohol but I'm not 100%
RockStar_199 is offline
Old 05-23-2014, 12:06 AM
Does the clutch engage correctly or slip excessively or you don't like how the truck launches?
post some pics of the shoes and the inside of your bell.
My ST-RR EVO is offline
Old 05-23-2014, 12:29 AM
it says on the instructions that come with buku clutches to lightly sand with a fine abrasive such as emery paper which will restore the clutch shoes to its original characteristics. reading the instructions never hurts
Old 05-23-2014, 05:00 AM
Maximo's Avatar
Grease and characteristics of use...from the pictures I seen the shoes were black and full of contamination......
I run that same clutch on my truggy, with a nastier engine and the same 15th gearing with no issues...difference is my shoes aren`t black, they are brown.............. Also I ran the clutch for roughly 4 gallons on my 28 and they showed near zero wear.......... So the clutch is more then capble of holding the engine and the gearing.... I think Element is having some sort of issue with oil/grease getting into the shoes....
Maximo is offline
Old 05-23-2014, 11:43 AM
It's not in the instructions but Philly has posted that in order to get grease oil or fuel off the shoes you need to heat them
Old 05-23-2014, 06:36 PM
I just bought 2 brand new buku clutches 34mm and it is in the instructions. there is a smaller piece of paper included which clearly says to use emery paper to clean them off.
Old 05-23-2014, 06:52 PM
I know but what meant was heating the shoes was not in the instructions.
