Trackmoist dust suppressant >
Old 05-19-2014, 06:10 AM
Trader Rating: 53 (100%+)
Default Trackmoist dust suppressant
I've been reading about this product on various motorsports forums has anyone tried this stuff on a RC track? How does it compare to calcium chloride or sugar/water mix?
http://www.trackmoist.com/
nv529 is offline
Old 05-19-2014, 07:03 AM
Trader Rating: 6 (88%+)
And if you've used it how do you apply it? I've been looking at it as well. But kind find any information on how it is applied and it what quantity.
Drip is offline
Old 05-19-2014, 07:30 AM
Trader Rating: 52 (100%+)
That stuff works for tracks with bad dirt. Meaning little clay. Did you build a track Nick? You can get samples of it in toledo.
Mo Denton is offline
Old 05-19-2014, 08:33 AM
Maximo's Avatar
how would it work on near pure clay ?
Maximo is offline
Old 05-19-2014, 09:03 AM
..or, clay with high sand content.
Ben Burtle is offline
Old 05-19-2014, 11:01 AM
kuruption's Avatar
Trader Rating: 24 (100%+)
Local track I race at regularly had a horrible dust problem and decided to give trackmoist a try this past weekend. To give you an idea, prior to this past weekend, at the end of the day, you were cleaning red dust off of everything in your pit area, and your car (I mean your transportation) would be covered with the stuff too... and hard to clean.
He added 6 oz. of Trackmoist to 1000 gallons of water, sprayed the track the night before the race. Total difference. Stuff wasn't covered, buggy was still dusty (it is offroad), but not nearly to the levels it was in the past... a paint brush was all that was needed to clean the buggy up.
I highly recommend the stuff if you have a dusty track.
kuruption is offline
Old 05-19-2014, 11:24 AM
Jeff Werner's Avatar
Trader Rating: 19 (100%+)
Does it change the surface performance wise or tire wear?
Jeff Werner is offline
Old 05-19-2014, 12:19 PM
Just what I was wanting to know.
Drip is offline
Old 05-19-2014, 12:25 PM
KingdomRacer's Avatar
+1
Could not believe the difference this weekend at that local track.
Stuff works period.
KingdomRacer is offline
Old 05-19-2014, 04:58 PM
BlueStreakOne's Avatar
Originally Posted by KingdomRacer View Post
+1
Stuff works period.
Great to know but how did it affect the surface and the tires?
BlueStreakOne is offline
Old 05-19-2014, 05:11 PM
cornerspeed's Avatar
Curious on the product myself. Will try it out on my track soon.
cornerspeed is offline
Old 05-19-2014, 09:31 PM
Surface felt more tacky (more grip).
Less runup and still make the jump with the extra grip and was making the triples with more ease now.
I felt less tire wear than normal and actually ran a set of soft enduros on my ebuggy with a different result than the last time I ran enduros on it.
The last time I had bald spots where the tires locked up from braking in just 1 round on this same track which is usually so abrasive.
I thought for sure I was going to regret running those tires... but that wasn't the case this time.
Old 05-19-2014, 11:55 PM
monty c's Avatar
Location: Dont get any more northwest than me..........
sounds like this is what my track is looking for. less dust, more grip but less tire wear? how often do you repeat the treatment? night before every race day? once a month? how lond does it last? and what about track wear, does in hold the track together better?
thanks guys, trying to talk the track into trying this stuff....
monty c is offline
Old 05-20-2014, 04:03 AM
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
we tried a similar product on our track.
They are a polymer agent that glue the smaller particles together in turn reducing the dust.
There's a few things you need to get right.
It has to be mixed into the tank really well for it to spread properly.
If you leave it in the tank it will separate and form a film on top of the water.
It will work best if you rotary hoe the surface breaking up the big clumps, spray it in and then roll the track.
Its reactivated by water. So dont use it during the race day, use clean water instead as re applying it will cause the trck to take a lot longer to dry before its raceable again.
Its broken down by sun light, so you have to keep doing it.
When you stop using it will be dustier and the surface will break up worse than before.
We dont use it anymore. We weren't using it surpress dust. We were using it to keep the surface together. When we stopped the soils natural ability to bind together was gone and the track fell apart. It took a few months for the soil to build up its binding ability again.
When using it the track became very greasy to race on during the night and wouldn't dry at all making for a muddy nights racing.
TIX is offline
Old 05-20-2014, 10:25 AM
Zerodefect's Avatar
It can't be sprayed on with a garden hose? Mixed with a fertilizer sprayer or something?
Track has no tank.
Zerodefect is offline
