Old 05-13-2014, 03:43 AM   #1
Default Novarossi Plus S4/ps Glow plug Q...
Hi I have this engine, this engine came with a standard glow plug,
I have a question is there any possiability to install turbo glow plug,
If not what are the best standard Glow plugs for this engine ???
Thanks for answeres
Mr.NitroBurner is offline   Reply With Quote
Old 05-13-2014, 06:22 AM   #2
HomicidalBunny's Avatar
Unfortunately, an engine that uses standard glow plugs cannot use turbo plugs; the threads and size of the plugs are very different
From Amainhobbies.com:
#4 - Very hot filament glow plug - used in high temperature conditions
#5 - Hot glow filament plug
#6 - Medium filament glow plug
#7 - Cold filament glow plug
#8 - Very cold filament glow plug - used in low temperature conditions
The best plug for you depends on your climate and what percentage of nitro fuel you use (25%, 30%, etc.). Typically, a lower temperature plug can be used with higher percentage nitro fuels, and vise versa.
TLR 8ight 4.0 / TLR 8ight-T 2.0
HomicidalBunny is offline   Reply With Quote
