Old 05-01-2014, 06:55 PM   #1
snoborder73's Avatar
Default 1/8 nitro truggy shocks
hi! if anyone could direct me to any threads/posts about shocks that would be great! otherwise,i know different shock weight is stiffer or lighter. but what do you use for dirt nitro. how to combine the springs with oil weight? (for the track)? is there a shock bible on here?LOL! thanks!
snoborder73 is offline   Reply With Quote
Old 05-01-2014, 07:10 PM   #2
buchanan88's Avatar
Depends on what type of track, temps and what you want the truggy to do. People cant just give you a magic number that works but can get you in the ballpark. Google JQ setup guide or Hudy setup manual that should get you going.
Huge thanks to my 2014 sponsors!
RCAMERICA|XRAY|NOVAROSSI ENGINES|BONES BREW FUEL|BETA TIRES|HOBBYPRO USA|UPGRADE RC|NEMORACINGUSA
#greasybrah#yacheckin#linkstyle
buchanan88 is offline   Reply With Quote
Old 05-01-2014, 07:45 PM   #3
Trader Rating: 6 (88%+)
What truck you running?
Reds racing USA
AKA
KO Propo USA
Sidewinder fuel
Upgrade Rc
Drip is offline   Reply With Quote
Old 05-02-2014, 08:16 AM   #4
Each car or truck with take a different shock set up. If you really want to learn: 1: start with the Standard Set up. This can be found on TLR.com
2: Download the Hudy Set Up Guide
3: Head to the track and practice.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 05-06-2014, 09:08 AM   #5
Frank L's Avatar
Trader Rating: 148 (100%+)
Start with stock and then tune from there. Follow the Hudy guide as above and when you make changes go for a larger change so you can feel the difference.
Old 05-06-2014, 10:31 AM   #6
alexzone007's Avatar
rc8t my setup front oil 35 rear 35 fill the oil on the shock 1/2 shock shaft out front and rear 1/2 or less shock shaft out piston 1.3 or 1.4 kyosho blue springs the best play with the droop screws on the arm and measure the arms with a caliper hight @ arm level rear
alexzone007 is offline   Reply With Quote
Old 05-07-2014, 12:48 PM   #7
Default setup guide videos
https://www.youtube.com/watch?v=o5MR4MxTsdw
https://www.youtube.com/watch?v=n0B46KBZKFw
https://www.youtube.com/watch?v=HNJy7kreK90
https://www.youtube.com/watch?v=P6WHGXq5nfA
https://www.youtube.com/watch?v=Z_5bc7zye3A
https://www.youtube.com/watch?v=H99PKqsUZjA
