Active Caster
Old 04-27-2014, 03:54 PM
Default Active Caster
Has anyone heard of a car that has active caster and / or knows how it works?
My ST-RR EVO is offline
Old 04-27-2014, 04:06 PM
Mugen.
LightningStruck is offline
Old 04-27-2014, 05:07 PM
Diff Balls's Avatar
Trader Rating: 39 (100%+)
Caster angle changes as suspension is compressed
Diff Balls is offline
Old 04-27-2014, 06:02 PM
Imbue's Avatar
Pretty much every pivotball car has it.
The upper and lower arms are at different angles, which causes the caster to change at varying rates. For instance, if your upper arm is nearly flat, or flat, and your lower arm has a lot of kickup, the caster would change much more dramatically from compression to droop than it would if the arms were at the same angle.
Imbue is offline
Old 04-27-2014, 06:19 PM
sweet. Is the active caster tunable?
Old 04-27-2014, 06:51 PM
Imbue's Avatar
If the buggy has inserts for the upper arms, such as the RR8, then it is tunable.
Imbue is offline
