Why are people still using antenna tubes? >
Old 04-19-2014, 12:41 PM
hookem34's Avatar
Trader Rating: 17 (100%+)
Default Why are people still using antenna tubes?
I know its kind of a silly question, but why are Pro drivers (and many others) still using antenna tubes? Everyone runs 2.4gHz now and there really is no need to do this?
Maybe it helps you spot your car a little easier on a large track?
hookem34 is offline
Old 04-19-2014, 12:46 PM
houston's Avatar
Trader Rating: 96 (100%+)
Many of the 2.4ghz rcvrs need the antenna , losing signal kinda suxx
houston is offline
Old 04-19-2014, 01:03 PM
Tyson72's Avatar
I like the look, even tho I haven't put my rx wire through the antenna for a few years now it still works fine, and on some tracks does help the vision with a longer antenna tube.
Tyson72 is offline
Old 04-19-2014, 01:42 PM
nitrokyosho's Avatar
I used them before just for looks but not any more.
nitrokyosho is offline
Old 04-19-2014, 02:02 PM
Trader Rating: 127 (100%+)
Only thing that saved me for a day of racing once now I always put them up. Had a KO kiy antenna break on me and couldn't get one at the track. Pulled antenna out of reciever box and tubed it. It gave me enough range to race.
ROSCOE is offline
Old 04-19-2014, 02:23 PM
skengines's Avatar
Trader Rating: 226 (100%+)
To help see the car better. I personally don't use one though.
skengines is offline
Old 04-19-2014, 04:27 PM
It's the trademark of RC Cars!
moto775 is offline
Old 04-19-2014, 04:55 PM
hookem34's Avatar
Losing signal would suck, but how often would a 2.4gHz signal get lost?
I mean, if airplane and helicopter guys don't need an external antenna, why would we?
I do love me some braaaap!
hookem34 is offline
Old 04-19-2014, 07:34 PM
tedstryker's Avatar
Trader Rating: 86 (100%+)
Using a long antenna tube on a large track helps alot .Even on a small track having an off camber turn in the corner of the track.
tedstryker is offline
Old 04-19-2014, 07:57 PM
beidle99's Avatar
Guys that fly Helis and planes on spektrum actually use satellite rx along with the main rx. Each rx has 2 antenna, so a heli or plane would have 4 antennas. 2.4 was new when I was flying and i didn't trust it from when it used to brown out running 1/12 scale, so no way was I putting it in a $2K heli.
I use to use a short antenna tube, now I go old school long antenna tube, looks cooler.
beidle99 is offline
Old 04-20-2014, 01:43 AM
Jaz240's Avatar
Trader Rating: 52 (100%+)
I only use Fioroni Modified antennae tubes. they make me faster
Jaz240 is offline
Old 04-20-2014, 02:02 AM
and in the air there are no obstacles like jumps etc..better be on the safe side and use a tube to get the antenna above the cooling head etc
Barracuda72 is offline
Old 04-20-2014, 03:19 AM
You still get better range with the antenna straight up. Try taking your wifi antenna and just coiling it up. You would have crap wifi then. Rc 2.4 uses the same spectrum that wifi a,b and g uses.
bhilly82 is offline
Old 04-20-2014, 06:23 AM
alport78's Avatar
I use sanwa receiver antenna allways in receiver box and never lost the signal. I still use antenna tube because I like the look but without any antenna in it
alport78 is offline
Old 04-20-2014, 11:24 AM
Rsickles's Avatar
Trader Rating: 21 (100%+)
Aerial radio systems generally have diversity antennas. Some even have sleeved dipole antennas, circular polarized, etc, to improve reception. While they may not always route them "externally", that does not mean they are not taking care to route the antennas effectively inside (both antennas at 90-degree diffefence, away from noise-prone electronis {ESCs, leads, etc}).
Our car systems have no diversity and just use a screened cable, so it's always a good idea to maximize the antennas reception - but mostly, it's all about keeping it away from noise (i.e. - wrapping it up in the radio box on top of a battery lead and surplus servo wires).
Just becaue you may "get away with" bad practices doesn't mean you do them.
Rsickles is offline
