Diffs
Old 04-09-2014, 10:34 PM
Default Diffs
Hi all, just wondered if rear diffs are the same as the front on an acme nb16 as nitrotek are out of front diffs and mine has broken.
Slatert16 is offline
Old 04-10-2014, 06:18 AM
ozziii's Avatar
Compare the front & rear in your car or try the rear in the front.
What has broken in your diff, if its the gears inside then they are most probably the same, it may only be the ring gear on the outside thats different.
I don't have the car so not sure about it but most would use same internal gearing.
ozziii is offline
