fuel filter in the exhaust preasure line.Whats it do? >
Old 04-09-2014, 04:43 AM
Default fuel filter in the exhaust preasure line.Whats it do?
Hi I have seen fuel filters in the exhaust pressure line and sometimes called stabilizers.Whats the benefits of this?I am building a losi 8 and I am wandering fit one?
martin34 is offline
Old 04-09-2014, 05:34 AM
Bugman's Avatar
In theory it,s supposed to cool the fuel inside the tank thus making you have better fuel mileage.Several companies make them Novarossi,Rb,Integy,Team Durango
Bugman is offline
Old 04-09-2014, 06:00 AM
Thanks very much for the explanation mate.Answer rc sell a fuel filter that can either be used as a filter or stabalizer so I mite aswell pick up two of them.
martin34 is offline
Old 04-09-2014, 06:17 AM
jeromerc's Avatar
There are two different things here. One is a cooler that is NOT a fuel filter. The other is an actual fuel filter. I also noticed a couple of Kyosho drivers that had 2 fuel filters on, the second was NOT a cooler but in fact a kyosho fuel filter. I do not understand why they run two fuel filters, does a fuel filter do the same thing as the cooler?
jeromerc is offline
Old 04-09-2014, 07:19 AM
ozziii's Avatar
They are 2 different items, the fuel filter has a small filter inside to filter out any crap that may find its way into the fuel, the cooler is for the exhaust line & is meant to cool the exhaust gases before they reach the tank, hopefully helping to keep the fuel slightly cooler as the exhaust gases are slightly cooler, its not designed to cool the fuel in the tank, either is the fuel filter.
ozziii is offline
Old 04-09-2014, 07:31 AM
Motorman007's Avatar
Trader Rating: 88 (100%+)
http://youtu.be/Ukdd_3764Pw
+ YouTube Video
Motorman007 is offline
Old 04-09-2014, 10:31 PM
KingdomRacer's Avatar
also holds more air from the exhaust and this helps keep the idle more stable.
kind of like having more fuel line...
KingdomRacer is offline
Thanks for the link to the vid.I am deffinatly to fit one.
martin34 is offline
Old 04-09-2014, 11:01 PM
Welcome sir
Old 04-10-2014, 12:14 AM
Roelof's Avatar
The larger volume filters do act more like a pressure chamber. It stores pressure and does damp the peak pressure from the exhaust giving the tank a more constant pressure.
Roelof is offline
Old 04-10-2014, 04:33 PM
wmazz's Avatar
Regarding the cooler: Nitro percentage decreases as temperature increases.
wmazz is offline
Old 04-11-2014, 09:06 AM
skirkman's Avatar
They also do this for maxim fuel compacity
skirkman is offline
