-   Nitro Off-Road (https://www.rctech.net/forum/nitro-off-road-130/)
-   -   servo help (https://www.rctech.net/forum/nitro-off-road/799491-servo-help.html)
jeff14346 03-11-2014 06:37 PM
servo help
running a Losi 8ight 2.0. using Savox 1258tg throttle/brake servo, updated to aluminum servo horn for throttle/brake, installed linkage, throttle attachment is rubbing on servo, ground some off the plastic still rubbing, the rubbing is causing a bind on servo action, looking for ideas?
ncdirtracer 03-12-2014 04:48 AM
I use a small washer out of a clutch shimming kit on top of the servo post then install your horn on top of it.
Race4598 03-12-2014 10:20 AM
I just put the linkage on top of the horn instead of the bottom. It will rub a little on the body but will not bind.
