Pro-Line X vs M tires >
Old 03-05-2014, 01:11 AM
Default Pro-Line X vs M tires
Has anyone tried Proline's X compound? I was in the process of buying some M4 Blockades (which I really like) and noticed they also come in X4.
My ST-RR EVO is offline
Old 03-05-2014, 01:42 AM
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
The X series are a little longer wearing. I only buy the X compounds now
TIX is offline
Old 03-05-2014, 03:18 AM
BigInJapan's Avatar
Trader Rating: 18 (100%+)
IMO, DEF go with x compound. Same grip ( I can't tell any difference ) much better wear life.
I'm using blockade in mx compound and it has about 2 hours on it with hardly any wear, yet it's still soft. I also use x3 diamond backs, my new fave tire
BigInJapan is offline
Old 03-05-2014, 04:07 AM
HomicidalBunny's Avatar
+1 on the blockades in X compound. Top tires.
HomicidalBunny is offline
Old 03-05-2014, 04:27 AM
TIX
TIX's Avatar
I've run the MX compound on a mallasis track for 45 minutes and still had tread left.
I really don't see why they still make the M compounds. The X compounds are by far superior
TIX is offline
Old 03-05-2014, 04:32 AM
What do you mean by mallasis?
Old 03-05-2014, 09:00 AM
Buster661's Avatar
X compound tires have less side wall flex and different rubber. They work great on dry abrasive tracks. If there is any moisture in the surface then M compounds are the way to go.
Buster661 is offline
Old 03-05-2014, 12:56 PM
Jaz240's Avatar
Trader Rating: 52 (100%+)
+1 the M compound is softer for sure. On a track that is watered or low abrasion the M compound works better. I think the X compound is Proline's attempt to try and get the same tire wear as AKA. I think if Proline and AKA could merge we could have 1 dominate tire company. Tread pattern choices from Proline and tire wear of AKA
Jaz240 is offline
Old 03-05-2014, 06:16 PM
Tyson72's Avatar
James would u say the X3 is closer to an M2 than M3?
Tyson72 is offline
Old 03-05-2014, 07:09 PM
Jaz240's Avatar
No it seems to be somewhere in between. I would call it M2.5
The compound is great and much better tire wear than the M compound but definitely a bit stiffer.
Jaz240 is offline
Old 03-05-2014, 07:44 PM
Tyson72's Avatar
M2.5, that made me laugh man
Yeah cool I see tessman ran his blockades in the x3 in the buggy A main at DNC.
I have the MX blockades for truck but haven't tried them yet. The M3 in truck are like chewing gum just stick to the dirt so well.
Tyson72 is offline
Old 03-05-2014, 10:41 PM
Sean Dickinson's Avatar
James here is on the right track. But with one part missing. The X compound is basically a more stable platform than the M. For our very rough high speed track, the X is much preferred because the M will grab ruts much easily and will have to take into account tire roll more so than the X compound.
I prefer the X compound for Fear Farm, which is very high speed and also very rutted despite what the videos show.
Sean Dickinson is offline
Old 03-07-2014, 01:42 AM
Thanks guys
Old 03-09-2014, 12:10 AM
Lille-bror's Avatar
Great info. Thanks from little Denmark
Lille-bror is offline
Old 03-09-2014, 01:02 AM
I'm going to try the x compound in a few days. Having already run the m compound I'll see how my results stack up. Thanks guys
