os vspec with losi 2.0 clutch set up >
Old 03-04-2014, 07:17 PM
Default os vspec with losi 2.0 clutch set up
car has been sitting for a year or so, went to remove the clutch bell from crank/flywheel, allen head is rounded, not able to get bolt to break loose to remove bell to get access to flywheel retaining nut. only option I see is to tr and drill out clutch bell bolt? any ideas??
Jeff
jeff14346 is offline
Old 03-04-2014, 07:20 PM
kgombe's Avatar
cut a slot with a dremel and use a good flat blade screw driver
kgombe is offline
Old 03-04-2014, 07:24 PM
Awsome!! will give it a shot!!
