ofna .32 gearing >
ofna .32 gearing
ofna .32 gearing
Old 01-22-2014, 09:13 AM
Arrow ofna .32 gearing
I have an ofna nexx 8t truck with the .32 force in it. It is a great engine, it holds a tune well, and starts easy every time. Really don't want to rid of it yet.
Stock gearing is 13t/48t and the truck has about no top end. I know the .32 is a tq monster and will not be a screamer. My question is, could I go up to a 15t bell without bogging down anything? This is a bash only truck, only time it sees a track it is just for fun.
hardrock2401 is offline
Old 01-22-2014, 03:45 PM
You can do that no problem, I run an alpha a352 (.23) on kyosho st-rr truggy gearing is 14/48 and pulls it no problem, I run 15/48 when im bashing around..it will wear the clutch a little faster but that probably wont be an issue for a torque motor..
hayes371 is offline
Old 01-23-2014, 11:22 AM
I have the same truggy w the 32. and run a 14 vented no issues
bob.less is offline
Old 01-23-2014, 03:54 PM
Did you experience any noticeable gains from the 14t?
Old 01-23-2014, 05:28 PM
BlueStreakOne's Avatar
13 to 14 is a very noticeable difference an that motor will pull the 15 like a semi pulls an empty trailer.
BlueStreakOne is offline
Old 01-26-2014, 06:21 PM
Thank you guys, I think I will try the 14 first.
Old 01-26-2014, 07:32 PM
Hoese37's Avatar
Biggest concern will be the clutch. Im guessing it still has the carbon shoes in it.
Hoese37 is offline
Old 01-27-2014, 07:35 PM
I'll be switching out for aluminum while I have it out
Old 01-28-2014, 03:04 AM
I did it to give it more of a nose up attitude off the face of jumps . more wheelspin. and to tone down the off throttle in turns. I dont know if your racin or bashin. I do both. I also use softer clutchsprings
bob.less is offline
Old 01-28-2014, 03:10 AM
I run the composite shoes for 3 reasons #1 theyre cheaper. # 2 they dont grab as quickly as alum. ones . and #3 less maint. no burrs to remove
bob.less is offline
Old 01-28-2014, 04:21 AM
If you search ofna nexx8t in nitro off road youll see more posts
bob.less is offline
Old 01-28-2014, 12:09 PM
-R2-'s Avatar
15 will still be good for the truck just lose a tad of acceration but you may not notice it because of bashing, on track then I would go back to 13 or 14 depending on track, plus you'll save some fuel with taller gear. You want more power and run time a tune pipe make all the difference a JP.2 will also help the top end and our 2047 (10074) is a better powerband with better fuel milage.
-R2- is offline
Old 01-28-2014, 01:24 PM
ya know........ its really nice to know that you OFFNA people watch the site ! thanks DJ
bob.less is offline
Old 02-12-2014, 08:53 AM
wound up ordering a 14t bell and a jp2 pipe hopefully the top end void will be filled now
