Runaways?
Old 01-19-2014, 08:22 PM
I Wheelie A LOT's Avatar
Trader Rating: 15 (100%+)
Default Runaways?
What causes runaways to be exact? I've had my 8ight-T randomly apply throttle by itself today, sometimes i even know when it's about to happen. I changed out my transmitter batteries, and even charged my receiver battery. It still manages to go crazy after running normally for about 10 minutes. What can be the cause of this? Thanks.
I Wheelie A LOT is offline
Old 01-19-2014, 08:56 PM
ThePanda's Avatar
Trader Rating: 68 (100%+)
Bad battery most likely. Some radio have a feature where the servos go into "failsafe" after the batt drops past a certain voltage. You can usually program where the servos will stop in the event of hitting the cutoff. It might just be hitting the cutoff quicker. Try programming tje brakes to come on in the even this happens again.
ThePanda is offline
Old 01-19-2014, 08:58 PM
Hoese37's Avatar
Bad servo, receiver, battery, or transmitter.
Hoese37 is offline
Old 01-19-2014, 09:12 PM
Servos are fine, transmitter is fine, receiver is new. I'm leaning a lot towards the battery rn
Where would i program this failsafe? The only failsafe i have right now is from the receiver which switches to full brake if i ever lose signal from the car. Problem is, when it does run away, it looks like it isn't from signal loss as it should switch to full brake right away.
Old 01-19-2014, 09:17 PM
Hoese37's Avatar
Are you using a LiFe pack by chance?
Hoese37 is offline
Old 01-19-2014, 09:26 PM
I'm using a 2s Lipo 2200mah from Losi
Old 01-19-2014, 09:46 PM
ThePanda's Avatar
some radios have a failsafe option in the radio settings.
ThePanda is offline
Old 01-19-2014, 09:48 PM
Isnt that the same thing as setting a failsafe in the receiver?
Old 01-19-2014, 09:52 PM
ThePanda's Avatar
Not exactly. you can buy an optional external failsafe, that connects to the receiver, but some radios have it in the radio settings as well. So if the radio looses contact with the receiver ,or the voltage going to the reviver droppes to low, you can set the servos, or motor to return to neutral, or go to a programmed point of travel. (turn on brakes) Some radios have this feature, and some don't.
ThePanda is offline
Old 01-19-2014, 09:53 PM
That's the exact same thing i have though
I'm using a Spektrum and i set my failsafes from the transmitter.
Old 01-19-2014, 09:55 PM
ThePanda's Avatar
oh. we are talking about the same thing then... are they set for a certain voltage cutoff?
ThePanda is offline
Old 01-19-2014, 10:02 PM
Hoese37's Avatar
Most likely a weak cell. Discharge it on your charger @2A and check the individual cell voltages.
Hoese37 is offline
Old 01-19-2014, 10:18 PM
Umm..where can i get a balance connector that fits a receiver?
All my balance connectors are for standard sized batts.
and No panda, i dont think they are.
Old 01-19-2014, 10:26 PM
houston's Avatar
Trader Rating: 96 (100%+)
Servo
houston is offline
Old 01-19-2014, 10:28 PM
Hoese37's Avatar
If your RX pack has no balance connector, then id toss it and buy a new one with the proper balance lead.
Hoese37 is offline
