Shock building
Old 01-14-2014, 07:00 PM
adrictan's Avatar
Default Shock building
So, I've always been wondering which exactly is a better way to set yr shocks.
Pistons' size aside, what's the difference between:
A shock with thinner shock oil but thicker spring
VS
A shock with thicker shock oil but thinner spring?
On a low-grip & bumpy surface, which would be the ideal? Low shock oil with lower spring rate?
adrictan is offline
Old 01-14-2014, 11:14 PM
Trader Rating: 50 (100%+)
Very useful information from Mark Pavidis on suspension tuning.
http://www.petitrc.com/reglages/BasicSuspensionTuning/
ForwardBite is offline
Old 01-15-2014, 08:03 AM
adrictan's Avatar
Thanks. Will take a look.
adrictan is offline
Old 01-15-2014, 08:10 AM
wittyname's Avatar
VS
A softer spring ,with oil thick enough to dampen the suspension movement and without being so thick that the tires bounce off the surface . Its a window really , not an exact number.
Check this thread out , I know it says "camber links" , but its more to it ... This guy is spot on in my opinion . http://www.rctech.net/forum/electric...ber-links.html
A thin oil , thick spring combo will be a fast shock , with a springy action to it and less dampening.
A thick oil , thin spring combo will be a slow shock , with a "wet rag" action to it.
wittyname is offline
