need help with my shockies please >
Old 01-01-2014, 01:58 AM
Exclamation need help with my shockies please
Hi
I run a GV cage and the shockies have given out and dont bounce back up properly i was wondering how i could fix this or if anyone knows if there r some 1/8 scale losi shockies that would be a replacment
RC rat is offline
Old 01-01-2014, 06:13 AM
beidle99's Avatar
Sounds like you bent a shock shaft.
beidle99 is offline
Old 01-01-2014, 09:32 AM
ThePanda's Avatar
Trader Rating: 68 (100%+)
ThePanda is offline
Old 01-02-2014, 10:34 AM
oeoeo327's Avatar
Trader Rating: 75 (100%+)
Could have bent a hinge pin as well. A badly bent hinge pin could keep the suspension from freely moving through its range of travel. If the shock is removed, the remainder of the suspension components should move freely. If they don't, check to see where the suspension is binding and replace parts as needed.
oeoeo327 is offline
Old 01-02-2014, 03:43 PM
The shocks move freely to their full range of movement but they dont bounce back up after being pushed down but if i pick the car up they go back to normal position so i dont think its a bent hinge pin
RC rat is offline
Old 01-02-2014, 04:03 PM
ozziii's Avatar
Sounds like they need a rebuild, clean them, change the seals & replace oils, put back together properly & you should be right to go as long as shafts & other perts are all in good condition.
ozziii is offline
