Like Tree70Likes
Xray XB8
Old 02-06-2019, 08:13 AM
  #3991
TheWorstDriver's Avatar
Originally Posted by dgrobe2112 View Post
I personally like the c-hub more. The steering and the aggressive style is more my suit. I am faster with the c-hub but not as consistent.
Hmmm, anyone want to trade all the C-hub parts for all the PBS parts? I mean if you are going to run C-hub only, and I'm going to run PBS, then a straight up trade for the parts bag out of the 2019 kits could make sense. Just a thought. I purchased two kits, (one for race day and one for practice), so I technically I have two full front ends I probably wont use. My second thought was to build one of each setup, and have a parts kit for each front end from the other kit. Slap the car on the track and see what worked better. Choices,.. choices...? LOL.
dgrobe2112 likes this.
TheWorstDriver is offline
Old 02-07-2019, 05:51 AM
  #3992
How much faster is it for you? How is it about a rough track and the c-hub from your own experience?
BenPetz is offline
Old 02-07-2019, 07:03 AM
  #3993
Trader Rating: 33 (100%+)
laptime wise, its upwards of a half second faster.. consistency is low with it though.. i have not had it on a rough track yet. the season here hasnt started up just yet.. so i been mainly club racing with it at the local track.
BenPetz likes this.
dgrobe2112 is offline
Old 02-07-2019, 10:06 AM
  #3994
Questions?? Xray XB8 2019 PBS vs C-Hub
laptime wise, its upwards of a half second faster.. hot lap maybe even higher.. i have not had it on a rough track yet. the season here hasnt started up just yet.. so i been mainly club racing with it at the local track.
A half second is huge when its repeatable. Looks like I'm going to need to try the C-hub. Do you think that decrease in lap time is mostly due to better rotation mid corner? Does it seem that the front end is hooked throughout the entire corner allowing rear to pivot a tighter line? Or do you feel the front pulls harder exiting the corner with better traction under power? You running loam or hard pack on that local track?
I'm running here this spring:
BenPetz likes this.
Old 02-07-2019, 10:15 AM
  #3995
We run on a high notb grooved track. Look up Thornhill racing circuit. Hard packed clay. It really turns in hard on the low speed corners. I think it has more corner speed and holds a tighter corner. Still working on dialing in the setup. It's not as consistent as the PBS at the moment.
BenPetz likes this.
Old 02-08-2019, 11:49 AM
  #3996
Thanks mate! Quite interesting. Looking forward what you say in a few months...
BenPetz is offline
Old 02-13-2019, 09:38 AM
  #3997
Trader Rating: 36 (97%+)
Will the 2017 XB8 body fit the 2018
alfanna909 is online now
Old 02-13-2019, 12:20 PM
  #3998
1evo RRR Driver's Avatar
Iíve seen a couple of converted C-Hub car now............. and I would have to believe if your gaining a half a second😳 with a C-hub car , something is wrong with your pillow ball car (setup)
1evo RRR Driver is offline
Old 02-14-2019, 06:38 AM
  #3999
not true.. when using the same setups from the same driver.. and dialing in.. there is about that much.. only problem i have is the consistency. My setups are identical to team driver setups.. most team drivers use Ty setup.. and tweak a little.. just as i do.. the setup from ty on the C-hub car.. tweaked just a little.. and im quicker with C-hub
Old 02-15-2019, 11:56 AM
  #4000
yes it will
Old 02-18-2019, 11:47 AM
  #4001
anyone been running the new 2019 much yet? im interested to see what everyones thoughts are on the new caps and bladders? i built my car using my old shock setup.. tried the new caps and bladders this past weekend for a day.. didnt really seem to like them with the same oil i had in the shocks from previous setup.. still some work to do.. they were very aggressive.. and didnt really do well on the rough parts.. did improve landing jumps.. but i ended up with the old caps and bladders..
also.. i got an updated setup sheet on the xray page.. planning on a few different things that should help get the consistency where i want it..
XRAY ::: Set-up Sheet - XB8'19
1. upper camber link, to outer hole on c-hub
2. 3* rear toe, going inner holes on the rear blocks
3. want to swap ride height, where front is higher than rear.. so.. 25/24 or 26/24 (similar to our setups on kyosho back in the day)
Old 02-19-2019, 10:34 AM
  #4002
Do you think the new caps have an effect to the performance? I thought this 4holes are only for easier bleeding and servicing. The bladder of course will make a difference. I ordered them but havenít received it yet but I will running it with the screw caps.
BenPetz is offline
Old 02-19-2019, 01:27 PM
  #4003
the new caps, and the new bladders, dont have much air trapped, or room for movement. the stock caps, or the bleeder caps have a little bit more air gap behind the bladder.
BenPetz likes this.
Old 03-07-2019, 08:35 AM
  #4004
Lil throw-back Thursday....
Thought you all might like to see an old 2006 Xray Buggy. I raced this one many years ago, completed 16 races in a row with this chassis, and won boxes full of blowing trophies. It was the lightest buggy on the track at this time, jumped better than anything, made quite a few club race A-mains with Drake and other top local pros. Good times! This new car is sooo much better, I cant wait!
2006'ish My 2nd Xray XB8
dgrobe2112 and BenPetz like this.
Old 03-07-2019, 08:38 AM
  #4005
panther tires.. what a throw back.. very cool story dude..
