Like Tree77Likes
Xray XB8
Old 01-18-2019, 02:16 AM
  #3976
What are the most common wear/ broken items? Gearing up for racing the end of this month I got a new to me 2017 model. I’ve seen A few of local guys breaking spurs.
Soyer is offline
Old 01-20-2019, 07:45 AM
  #3977
rjmakk's Avatar
Originally Posted by Soyer View Post
What are the most common wear/ broken items? Gearing up for racing the end of this month I got a new to me 2017 model. Iíve seen A few of local guys breaking spurs.
I've broken a top front arm, a silver pillow ball, and a rear arm. I've also lost a Steering plate bushing but that was my fault; DGrobe hooked me up with that part so that was awesome! So basically, arms and some random extra screws and parts. It's hard to know what and hard to budget, but start with arms. Enjoy!
rjmakk is offline
Old 01-20-2019, 07:54 AM
  #3978
Trader Rating: 88 (100%+)
I broke a steel pivot ball yesterday. Just hit a pipe and snap! Spur gear, front arm and shock shaft. Thatís all I broke so far. I would get a pin replacement tool and pins to replace when they get flat. The mugen tool is best.
b121774 is offline
Old 01-20-2019, 10:46 AM
  #3979
Trader Rating: 33 (100%+)
I try to keep spares of kost stuff.. bit rarely need them.. I never broke a pillow ball.. but I would do arms for sure.
dgrobe2112 is offline
Old 01-20-2019, 12:06 PM
  #3980
Life_livin's Avatar
Trader Rating: 20 (100%+)
I would do at minimum arms, spur gear, steering bell crank, shock ends, shock bushings, shock shafts, rod ends for steering turnbuckles, and rear outer hinge pins. I always carry a spare tank as well, the way the pipe hanger mount rubs on it always has concerned me but I've never actually needed it.
Life_livin is offline
Old 01-21-2019, 02:32 PM
  #3981
This ^ Is exactly a thing what I have observed at my and a few others XB8 2018 buggy’s too. Everything is very close in this area and my tank is also a bit rubbed and light damaged from the pipe hanger and I haven’t raced much with this buggy yet. Don’t know if there’s a bit more space at 2019 buggy but from the images I have seen it seems to be the same.
BenPetz is offline
Old 01-21-2019, 02:38 PM
  #3982
kuruption's Avatar
Trader Rating: 24 (100%+)
No room to bend the hanger?
kuruption is offline
Old 01-21-2019, 07:39 PM
  #3983
My driving is pretty rough so I’ll defintly order a tank
Soyer is offline
Old 01-22-2019, 10:59 AM
  #3984
rjmakk's Avatar
Originally Posted by BenPetz View Post
This ^ Is exactly a thing what I have observed at my and a few others XB8 2018 buggyís too. Everything is very close in this area and my tank is also a bit rubbed and light damaged from the pipe hanger and I havenít raced much with this buggy yet. Donít know if thereís a bit more space at 2019 buggy but from the images I have seen it seems to be the same.
If you have a torch, heat it up and bend it out of the way. I did one of mine, but the other leaves the fuel tank not looking so stoked.
rjmakk is offline
Old 01-26-2019, 07:04 PM
  #3985
TheWorstDriver's Avatar
Anyone track tested the stock/manual setup to a T? Getting ready for spring racing with my 2019 XB8, medium bite, some loam, large track. Built the PBS version, slapped it down a couple times so far for some practice, not sure I'm changing anything, kind dialed out of the box. What say you?
TheWorstDriver is offline
Old 01-28-2019, 09:00 PM
  #3986
rjmakk's Avatar
It sure is! You can try 4 dot spring up front.
rjmakk is offline
Old 01-29-2019, 09:18 AM
  #3987
Same shock oil, or did you go up with the spring? Off power steering change much?
Old 02-05-2019, 07:30 AM
  #3988
FYI, parts support, for the C-hub parts are coming in stock at all your hobby shops, and at RCA..
Old 02-05-2019, 07:06 PM
  #3989
CAR
Any new updates on how the c-hub performs on the car vs the pillow ball now that the car has been out for a while?
CAR is offline
Old 02-05-2019, 07:13 PM
  #3990
I personally like the c-hub more. The steering and the aggressive style is more my suit. I am faster with the c-hub but not as consistent.
