Like Tree88Likes
Xray XB8
Old 01-09-2019, 03:34 PM
  #3961
kuruption's Avatar
Trader Rating: 24 (100%+)
There are other things to consider. The 34mm flywheel will protrude farther through the chassis, so if you flat land it will also cause the car to shut off. When I first started running Xray, I tried the Losi 34mm flywheel and had this issue... I ended up switching to the Buku clutch because the spring rate is adjustable via set screws, and that was a 32mm.... never had a problem.
You can try raising your motor 1mm to provide the extra clearance from the chassis, but that has center of gravity consequences and doesn't really solve any issues you'll have if you're hitting the brake pads, too.
kuruption is offline
Old 01-10-2019, 04:07 AM
  #3962
Trader Rating: 89 (100%+)
I’ve been running the associated clutch and have had no problems.
b121774 is offline
Old 01-10-2019, 05:20 AM
  #3963
kuruption's Avatar
Anyone know the length of CVD shaft 355221? I think I have a few sitting in my box, but without any markings on them and without any length figures, I don't know what I may have.
Mine are 102.5 and appear to fit well, so I am guessing they are the right ones. Going to have to pick up some pins to get these built though.
Old 01-11-2019, 12:12 PM
  #3964
@dgrobe: Thanks for your report about the first c hub test. I am curious what you will say after a few more tests. For me I will stay with the 2018 Version because I like the PBS a lot and will upgrade to the newer rear arms, front arms and longer shock shafts. One question which you maybe can answer: The new hub for the PBS is a centered version again, what is the difference between this and the one from the XB8 2016? Different compound?
BenPetz is offline
Old 01-11-2019, 01:26 PM
  #3965
Trader Rating: 33 (100%+)
yes.. its still centered.. they made it where the outer bearing is bigger. thats the only difference. the 2019 car comes with the 2016 alum steering block that screws to the hub btw.. 2 dot is now the part. but its the same as the 2016 plate which we were all using.
Anunnaki and BenPetz like this.
dgrobe2112 is offline
Old 01-11-2019, 01:30 PM
  #3966
also.. for this weekends races.. i will be sticking with the PBS until i can get the cosistency with the C-hub.. and have the parts to do my other car as well..
Old 01-11-2019, 01:56 PM
  #3967
let me know what questions yall have.. i will answer as best i can.. also.. got some idea i am going to work on for the C-hub.. few people have mentioned possibly the chance of the set screw coming loose on the upper arm.. i got a couple ideas a few guys working on.. and i got another idea.
uDi_MP7.5, Anunnaki and BenPetz like this.
Old 01-11-2019, 03:26 PM
  #3968
Thank you! Ahh, yes of course the bigger bearings I have totally forgotten this topic. Interesting info also for the steering block. I will also try to get one for my 2018 buggy.
BenPetz is offline
Old 01-11-2019, 03:39 PM
  #3969
Yes, first time as I have seen the set screw for the upper arm in the c hub configuration I thought also this could be a really weak point because a lot of forces can come there at jumping etc. I could imagine xray will bring an option part for this area in the future. What I would do in the meantime: replace the setscrew with a real tiny longer headscrew and use good loctite or too secure it more: use more then one set ring&screw on each side per arm.
Other questions I have: 1. is it worth to upgrade to the longer shock shafts? 2. I have seen almost all pro‘s are running the universal shafts in the center drivetrain of the car but cvds front and rear. I guess the universals are for a more free drivetrain. Is this really noticeable instead of using the cvds in the center drivetrain?
Thx in advance
Ben
BenPetz is offline
Old 01-11-2019, 08:22 PM
  #3970
symmetricon's Avatar
Trader Rating: 27 (100%+)
Thx in advance
Ben
You could easily grind a flat spot on the upper hinge pin where the set screw attaches to it. I would think that would be secure enough if one doesnt think it is already secure enough.
And yes, the longer shock setup is excellent, a must have imo. And the new shock caps are great as well.
BenPetz likes this.
symmetricon is offline
Old 01-12-2019, 02:26 AM
  #3971
speedy2's Avatar
French pro driver Cedric Nickel from kyosho to Xray
speedy2 is offline
Old 01-12-2019, 03:26 PM
  #3972
Trader Rating: 28 (100%+)
Hi all! I have a 2016 XB8 and I am wondering if I can replace the chassis with the newer 2018 version, are they compatible? I read that It's a bit longer which should make the car more stable on rutted tracks. If so, are the stock center CVD's compatible> Thanks! Mike
madness is offline
Old 01-14-2019, 08:10 AM
  #3973
yes you can. its not very much longer than you should have issues.
Old 01-15-2019, 08:17 PM
  #3974
uDi_MP7.5's Avatar
Hooray, the new PB knuckles use dual 8x16 bearings, now making the entire XB8 drivetrain 8x16mm if you use 4x universals (as per stock 2017 XB8).
Everything should retrofit to '16,'17,'18 kits.
I know the 2019 uses CVDs in the rear (thus 13x19 inner bearing), but for anyone who doesn't know, those rear hubs fit both sizes of bearings on the inside so if you switch to universals you can run the 8x16s.
I think this is absolutely excellent given that many other brands are rapidly switching to smaller bearings, particularly tiny ones on the diff pinion (cough MP9, MBX8).
I find 8x16 (larger balls) to have much better longevity than both 13x19 and 8x14 sizes, so you can have a smooth trouble-free drivetrain much longer.
Maybe some prefer the CVs, I have both shaft sets and can't tell a huge difference, but prefer the longer bearing life given the choice.
In fairness, with the 8x16 outside now even the 13x19 with CV setup should last longer than in past.
I prefer the CVs on center because it's very easy to remove them to change worn drive pins, which in my experience happens much faster on the center shafts (much higher linear velocity on center pins).
No need to undo loctited grubscrew or change pinion lash (/ lack thereof), can just pop off boot+circlip to remove shaft.
Great to see a familiar name from the RCCA days dgrobe2112, I wonder what happened to atm92484.
Just getting back into it after a break, appreciate all the contributions.
symmetricon likes this.
uDi_MP7.5 is offline
Old 01-16-2019, 03:42 AM
  #3975
kuruption's Avatar
The pillow ball hubs also support both bearing sizes, if you decide to run CVDs up front.
