Like Tree82Likes
Xray XB8
Old 07-31-2016, 12:52 AM
  #3241
Trader Rating: 33 (100%+)
ok.. so with some testing today.. i was able to get #3 hole to work, and not lock the steering.. i added 1mm bump steer on the wheel.. which made it a total of 3mm.. and the wheels dont lock..
other than that.. i was also able to test out some springs.. the mugen 9.25 in front.. and i ended up with the 10.5 rear mugen springs.. really woke the car up..
i think a few of you guys who may be getting a lil more diff action up front.. might like 7k in the front.. currently i am at 7/5/3 in my diffs as well..
going to try some lighter shock oil think im going to go 650/600.. with the AE piston setup..
but just wanted to give a heads up on the front steering lock that i was able to fix
dgrobe2112 is offline
Old 07-31-2016, 05:26 AM
  #3242
firecat's Avatar
I have been running k cars for years and was looking to try something different I currently run an xb2+4 on carpet and turf and was gonna look into the 8 but don't really want a car that has a problem with steering hopefully they will sort out the problem will check back to see if anything has been resolved
firecat is offline
Old 07-31-2016, 09:27 PM
  #3243
Frank L's Avatar
Trader Rating: 148 (100%+)
I just checked my can and in the air there is no binding. I'm running kit bump steer and the 3rd hole back on the Ackerman (hole #2 on the pic last page) Just took a couple races to break in.
Frank L is offline
Old 08-01-2016, 01:47 AM
  #3244
The steering bind issue is definitely not a matter of breaking the car in.
I have run several races and the steering bind is pretty much the same as when the car was new (I can say that with confidence as i have one car that is raced quite extensively and a brand new one on my shelf).
Also, if it was a matter of breaking the car in, it would be quite misleading to release a tech tip advising that the stock setup can't be used without inducing a mechanical issue as everyone accepts a break in period.
You can of course circumvent the whole issue by lots of creative solutions (which are likely to impact performance one way or another), but the fact remains that the setup that X-ray recommends as the best starting setup simply doesn't work.
Bernard B is offline
Old 08-01-2016, 02:21 AM
  #3245
all customers here in rctech should contact xray at [email protected].
to discuss these things here is ok, but it would help more to give feedback direct.
i am not satisfied with my product till now (thereīs obviously an issue with o-rings in the diffs as well).
diffs are leaking very intensely.
hopefully just a bad batch o-rings...
gt racing is offline
Old 08-01-2016, 07:48 AM
  #3246
The problem are not the orings... It is between the metal insert and the diff plastic case molded into it. There are several photos and videos showing this problem, here on RCtech and also on xray's facebook page.
patrickgarcia is offline
Old 08-01-2016, 08:01 AM
  #3247
lewis4x4's Avatar
We came from the K Cars after running for many years. If you like the XB2 and especially the XB4, then you will love the XB8. We have not had the steering issues that several have been referring to. Not saying that it doesn't exist, but we have not had one single problem.
lewis4x4 is offline
Old 08-01-2016, 10:26 AM
  #3248
Thank you for this Input, but NO its not the diff case, 100% the orings.
Old 08-03-2016, 12:55 AM
  #3249
made the comparison between part no. #971060 from xb8 2014 and xb8 2016.
both new, 2014 is bigger.
there must have changed something, the 2016 o-rings are clearly too small.
i am in contact with xray.
my buddys xb8ī16 same, diffs are empty within a few tanks.
...this is just for your information, i donīt need building advice folks.
xray in their first response told me how to build diffs lol, i told them same, no building advice needed.
itīs simple:
appreciate help/feedback from paying customers and DO RESEARCH!
...to be continued...
Old 08-03-2016, 06:42 AM
  #3250
Thanks for the update! i have the exact same issue, diffs are empty after a day at the track.
Really annoying with the center diff as the leaked oil makes the brakes totally inconsistent and the bearings super sticky.
Old 08-03-2016, 07:33 AM
  #3251
cool to have issues in mid season, ... NOT.
btw., steering servos wonīt like the steering lock, regardless if there is a servo safer or not. most racer adjusting it pretty strong.
Old 08-03-2016, 07:55 AM
  #3252
@Bernard B, please report this back to [email protected]
this o-rings are definitely a bad batch or something like that.
@all, check o-rings, check leakage at your diffs.
Old 08-03-2016, 09:43 AM
  #3253
lewis4x4's Avatar
I'm not gonna say I know why the problem is BUT most of the time when this happens, it is because the diff had too much oil in it when it was built. I watch so many people build them incorrectly. During a run, the diff builds up pressure and when the diff is too full, the pressure causes damage to the case and/or forces oil to leak. When you build the diff, make sure the oil is just barley above the cross pins. Anymore that that and it's too much.
lewis4x4 is offline
Old 08-04-2016, 02:32 AM
  #3254
Already did, waiting for a reply from the technical department. Both on the steering lock that took its toll on my new 150 dollar servo and the leaking diffs.
These diffs leak now matter how little you put in them, unfortunately. i do agree that it takes quite a bit of accuracy to get the diffs right regardless of brand.
Old 08-05-2016, 08:59 AM
  #3255
symmetricon's Avatar
Trader Rating: 27 (100%+)
I've had zero problems with the steering and zero problems with the diffs leaking...
symmetricon is offline
