Best tires for 1/10th scale buggy >
Old 12-08-2013, 02:00 AM
Default Best tires for 1/10th scale buggy
Hi. I have an Acme Condor Pro which is a self build kit. I want to change the wheels as when I go to maybe 30 mph+ it starts wobbling on tarmac. Also, I want as much clearance as possible between the chasis and the ground as when I go off road it can't cope with the grass so well. I just wondered if I should get adapters to fit a bigger wheel onto the car or not? Also, are there any sites which sells tires for cheap. I was thinking maybe £20 to £30 budget. I think it is a 12mm hex but I will double check that later on.
12mm hex confirmed
crazyduck is offline
Old 12-08-2013, 11:11 AM
ThePanda's Avatar
Trader Rating: 68 (100%+)
Buggy's are not meant to be run on grass. that being said, any 1/10 4wd buggy tires and wheels should fit just fine.
ThePanda is offline
