Replacement engine for team infinity .18? >
Old 11-21-2013, 02:15 PM
Unhappy Replacement engine for team infinity .18?
I recently did a post RE a broken Hsp bug crusher.. BRAND NEW from nitrotek delivered with loose head bolts to find one snapped bolt and the hole for it 1/4 the way in is sheared and the bolt just pushes in and out.. Thanks to there appalling customer service I'm beginning to think I might be able to make the best of it an just replace the engine myself? As I'm told there's no way to fix this problem -.- But I can't seem to find one and am unsure of alternatives? Any help or suggestions would be great
DirtyB1990 is offline
Old 11-22-2013, 05:52 AM
measure from hole to hole on one side and hole to hole across from each other. then look at specs. from other engine manf. and see if the measurements are the same. OS makes a .18.
ncdirtracer is offline
