VP Pro world
#151
Pictures from VP-PRO Canada driver Phil Todd
#152
Any plans for 1/10th scale truck tires?
#153
VP-PRO Welcome Germany new distributor SK SPEED
Good news! VP-PRO is back to Germany market with our new Germany distributor SK SPEED.com. Believe you can access the supper quality merchandise conveniently in Germany, welcome SK SPEED join in VP-PRO and thank you for your support.
#154
Yes, making artwork
#155
#156
Sounds good! Do you have plans for 1/10th scale astroturf tires, too?
#157
#158
POWER STAR servo practical test video
In order to show you POWER STAR servo superior performance directly, we took a video when our professional driver Kaicheng Li tested POWER STAR servo at the local stadium. The wonderful video can make you feel very exciting and experience the great test field. Welcome to click the link:https://www.youtube.com/watch?v=sHDw...ature=youtu.be
Website:http://powerstar-racing.com/
E-mail: [email protected]
#159
Congratulations
The second round of the Italian National Champion took place, VP-PRO driver Davide Tortorici got the third place
http://www.neobuggy.net/2014/04/27/alex-zanchettin-claims-italian-champ-rd2/#more-43144
#160
#161
Bit of a problem I came across this weekend which really screwed up my days racing.
Fitted a brand new set of white dot grips at the start of the day,these tyres usually work great on our hard packed loose track but car was all over the place,ended up chasing a non existent setup issue on the car all day where the car was loose one corner tight the next and would jump skewed off the on power small jumps.
After the finals had done I decided to rinse the tyres off and noticed 2 of the tyres were much harder than the other 2..so I had been running all day with 2 hard and 2 soft tyres on opposing corners even tho they were all white dots.
Not a happy bunny and worth keeping an eye on if anyone else has had the same issue..I mean the difference in the sidewall stiffness .is massive too.
#162
#163
Also, the foams vary in size and density from batch to batch, so make sure all 4 are the same before mounting.
It happens at all factories. The last set of Proline tires I got had 1 Bow Tie and 1 Crimefighter in the same bag and several times the tires were marked with the wrong color dot over the years I drove for them.
#164
They were preglued tyres...which must have been glued with wood glue because 3 of them came off the rims after the final,half the tyre was off the rim.
#165
I've never used any preglued off-road-tyres, but most preglued TC tyres I used in the past needed attentention after running one pack at the latest.
As for PL, my club president still has a "pair" of Holeshots with one 4WD front and rear tyre each!
