Looking for help with a build >
Old 11-18-2013, 01:28 PM
Default Looking for help with a build
Hey, I'm new to the forum here. I was looking to build myself a 1/8 scale sandrail. I plan on building the frame and chassis myself using tube for the roll cage. (probly steel brakeline) and some aluminum for the bottom of the chassis. You guys might laugh at me for this, but I was looking to use some parts from my exceed rc madstorm pro with the .28 engine. Most likely just the engine, servos and other small things from it. I was thinking of using the traxxas jato front suspension and traxxas stampede for the rear. I want lots of travel front and rear. Any ideas from the people on here that have done sandrail builds?
Thanks in advance
kurt2938 is offline
Old 11-18-2013, 08:21 PM
Jerm13's Avatar
Trader Rating: 36 (100%+)
Thanks in advance
You will be able to get more travel if you use shocks and springs from a 1/8 truggy or even from the 1/5 Baja line. Check e-bay and the F/S threads for some good deals.
Show us some pics of your progress.
Jerm13 is offline
Old 11-18-2013, 10:19 PM
xyzyx00's Avatar
sounds like a neat project... i too would like to see some pics
xyzyx00 is offline
Old 11-19-2013, 07:23 AM
rubiconon37's's Avatar
Thanks in advance
The traxxas stuff is only 1/10th scale. It won't hold up to anything a 1/8th scale could put it through. The jato steering parts are very week and the stampede rear end is week too. The plastic axles definitely will not handle a .28!
rubiconon37's is offline
Old 11-19-2013, 09:25 AM
Hey all, thanks for the input. I kinda thought a stampede rear end and jato front end would be a little weak. Those seem to be the ones everyone else is using, but they must be using 1/10 scale motors with it. Any other rear ends I should use? I'Ll likely need a slipper clutch as well and a strong differential. And for those of you wanting pics, I'm not sure when I'll be doing this project. Im just trying to get all my info together. But I'Ll definitely try to post pics of the during and after shots
kurt2938 is offline
Old 11-19-2013, 09:33 AM
I think a revo rear end would be slick, but I dont have a clue how that would mount on a diy chassis. Those revo chassis are... different.
kurt2938 is offline
