Smooth throttle vs blipping throttle. >
Old 11-08-2013, 11:20 AM
mattjk's Avatar
Trader Rating: 81 (100%+)
Default Smooth throttle vs blipping throttle.
I see this a lot. I try to use smooth linear throttle movements to get around the track, and then I see some people constantly blipping the throttle. It's annoying especially when it's nitro.
What's your style of driving and why?
mattjk is offline
Old 11-08-2013, 11:28 AM
I'ma noob but I used smooth throttle because I'm used to playing sim games. Now I find myself blipping because it keeps the RPMs up through the slow sections.
Silo is offline
Old 11-08-2013, 11:33 AM
mattjk's Avatar
hmmm, interesting. however with a good tune you don't need to keep the rpms up. i'm assuming to keep it from loading up on the bottom end?
mattjk is offline
Old 11-08-2013, 11:38 AM
I think he is talking about keeping up the speed in the corners. Short bursts
Chris Reilly is offline
Old 11-08-2013, 11:45 AM
rfleck's Avatar
Trader Rating: 58 (100%+)
Blipping the throttle wastes fuel and causes unnecessary weight transfer from front to rear. It's a bad practice although almost every nitro driver is guilty of it, myself included. If you can keep from doing it you will most certainly be faster.
rfleck is offline
Old 11-08-2013, 11:55 AM
Yeah, I find blipping faster than smooth throttle on corners and small bumps. For exiting long corners smooth throttle is defiantly better. I think it depends on the track, again, noob here(let me know if I'm doing this wrong), but I use both depending on how the track is setup.
Silo is offline
Old 11-08-2013, 12:22 PM
Herrsavage is offline
Old 11-08-2013, 12:25 PM
am
I like the smooth aproach. It keeps me in Control better as i am not to good on the "wrc" driving style from the 80`s. I find my laptimes 0.3-0.5 of the fastetst drivers in Norway. There is only a couple of guys here that gets as good fuelconsumption as i am. On the other side, i would have gone fatser if i learned the Wrc style, but fuelconsumptions is going Down drastic when i try to drive like that. And when i makes mistakes it costs me alot more :-)
am is offline
Old 11-08-2013, 01:42 PM
Harryaus's Avatar
I don't only blip on the throttle, also have a bad habbit letting go of steering wheel on corners. Anyone els or am I alone with this bad habbit
Harryaus is offline
Old 11-08-2013, 01:46 PM
Blipping the throttle is good if you have a badly carburated engine prone to loading up with fuel when on low throttle and then stalling when you push the throttle again. If you're carburated correctly, then it shouldn't be necessary.
I'm a firm believer in being smooth on the throttle.
Eivind E is offline
Old 11-08-2013, 01:59 PM
Imbue's Avatar
I think you'll find the majority of pros are "blippers" to some extent. That said, do what you're most comfortable with.
Imbue is offline
Old 11-08-2013, 02:09 PM
CoryD's Avatar
The most epic "blipper" I have ever seen HAS to be Richard Saxton. I don't even know how he can "blip" so many times per second!
Tebo is right up there too; even in 1/10 Electric.
CoryD is offline
Old 11-08-2013, 02:27 PM
Trader Rating: 37 (97%+)
I drive an e buggy and recently went to nitro also and I had trouble with the smooth approach. I am very smooth on the throttle with e buggy but with nitro it just didn't feel right to me. I always went back to blipping. I could drive smoother that way and it doesn't hurt my fuel mileage. Now I catch myself even blipping my e buggy too and to be honest it helps me around the turns.
charlesandstuff is offline
Old 11-08-2013, 02:29 PM
BillyT.'s Avatar
It really has zero to do with the tune.
BillyT. is offline
Old 11-08-2013, 03:57 PM
that's the only reason I can see, other than that you wouldn't need it.
I never do it.
Eivind E is offline
