convert 777 to big bore shock set up
If any one could steer me in the right direction on a set of big bore shocks for 777 chassis it would be great. They definitely Dont need to be kyosho shocks, also I've heard that front and rear universal shafts need to be changed along with top mounts on shock towers. The help would be greatly appreciated.
mp9 shock set from www.dollarhobbyz.com and I believe the mp9 universals will also fit as far as shaft length
You will need the front shocks off the MP9 and the rears off of the ST-RR. The MP777 uses a longer rear shock than the MP9. You're on your own for non-Kyosho alternatives. If you're racing, use the Kyosho shocks. Also, you will need the taller shock stands for the towers. Infernosonly is a great source for needed small parts.
The standard front universals will rub with the big bores, so use the lightweight front universal set.
Good luck!
Good luck!
Just keep the stock shocks.. Theres even a guy with a 777 with the stock shocks at my local track and he does really well with it. By the time you upgrade universals and get the kyosho shocks you will have spent more than the buggy is even worth.
777 thanks
Thank you for the help . run kyosho, ofna, mugen and associated. Sticking with a roller is what I want to totally achieve and get the best out of until I can achieve the most.
