Battery chargers >
Battery chargers
Battery chargers
Old 10-21-2013, 10:49 PM
Default Battery chargers
Hi i want to buy a peak fast charger that can discharge and charge 7.2v batteries and glow igniters.
Any reccomendations
dazablue is offline
Old 10-21-2013, 11:51 PM
coneman's Avatar
Any reccomendations
the one i showed you in your other thread will do you. cheap and will do anything you want.
http://www.amainhobbies.com/product_...rger-6S-5A-50W
coneman is offline
Old 10-22-2013, 12:33 AM
Ye but there is no tamiyar connector
dazablue is offline
Old 10-22-2013, 12:42 AM
coneman's Avatar
no one uses tamiya connectors. if you're still using tamiya connectors you need to change them. they will eventually melt together. get some deans ultra plugs at least. you will get better run time and more power out of the battery.
http://www.amainhobbies.com/advanced...s+plug&x=0&y=0
coneman is offline
Old 10-22-2013, 01:11 AM
I don't know how to change it from tamiya to deans and can i just change it in my starter box from tamiya to deans without it harming my starter box.
dazablue is offline
Old 10-22-2013, 06:14 AM
coneman's Avatar
do you know someone with a soldering iron. if so ask them to do it for you. you'll have to change plugs on starter box and battery.
coneman is offline
Old 10-22-2013, 06:35 AM
coneman's Avatar
or you could get one of those chargers and one of these charge lead squids that has a tamiya plug and you'll be good to go.
http://www.amainhobbies.com/product_...arging-Adaptor
coneman is offline
Old 10-22-2013, 07:56 AM
rcmodelswiz's Avatar
I learn a lot from you guys. Thank you for the recommendation. This is also my concern. I'll check them.
rcmodelswiz is offline
Old 10-22-2013, 02:17 PM
Would I be able to use that tamiya connector on that charger you recommended
dazablue is offline
Old 10-22-2013, 07:39 PM
coneman's Avatar
yeah
coneman is offline
Old 10-23-2013, 06:56 AM
Frank L's Avatar
Trader Rating: 148 (100%+)
Get a squid. The. You have every charge lead you could ever want. Just only plug in 1 at a time.
Frank L is offline
Old 10-23-2013, 08:18 AM
http://www.amainhobbies.com/product_...attery-Charger
Everything you need.
LightningStruck is offline
