Antenna issue
Old 10-18-2013, 03:29 AM
Default Antenna issue
I,m going to the track tomorrow and the antenna holder that holds the antenna broke on the side. The antenna usually gets tightened with a screw but since the antenna holder broke I can't tighten the antenna. The antenna can still go in the hole but it is loose and can fall out so are there any ideas to keep the antenna in as I can't order a new part because I'm going to the track tomorrow.
I use a spektrum 2.4ghz transmitter with a spektrum 2.4ghz reciever if that helps.
dazablue is offline
Old 10-18-2013, 03:47 AM
Imbue's Avatar
Dab of CA or Shoe-goo.
Imbue is offline
Old 10-18-2013, 03:57 AM
AllyITA's Avatar
i run with the antenna wire inside the receiver box without problems (sanwa 2.4GHz)
used to do the same with planes (spektrum 2.4GHz)
AllyITA is offline
Old 10-18-2013, 04:10 AM
Won't that cause range issues???
dazablue is offline
Old 10-18-2013, 04:27 AM
AllyITA's Avatar
probably it can, but if you're going racing i doubt you'll be at a track that big to cause any issues, never happened to me.
i have tested that i'm fine for more than 100 meters (300 ft)of range
AllyITA is offline
Old 10-18-2013, 04:36 AM
Thank you so much allyita
dazablue is offline
Old 10-18-2013, 04:40 AM
speedy2's Avatar
you could glue the antenna tube to the sideguard too
speedy2 is offline
